SIMBA Fibre Broadband
Nefalrin
Maybe Simba using Tesla satellite internet so can reach 10gbps but connection is for surfing net only 🤣
ShaiDoesMac
10Gbps local connection, not to the wider internet.
Starlink would be a nice option if it was offered in Singapore, but obviously in Singapore HDB you gonna have a full roof clusterf'ed with satellite dishes instead of solar panels.
syihabuddin
Anyone here on SIMBA suddenly got a dead connection?
My ONT has had the PON light flashing since the last 2 days. It was working fine prior. I suspect it’s related to NLT’s recent work done.
Reached out to SIMBA on 4th and got a template initial troubleshooting reply. My house area mobile coverage is damn shitty so I’m at a loss here as to what I can do…
What’s done to self-troubleshoot:
1. Power cycle ONT after 5 mins of being off.
2. Switch to a known to be good patch fibre cord.
3. Flipped fibre cord around.
4. Switched to other FTP port. This results in LOS.
Sengkang area, specifically Compassvale Road. Help?
LOL
PS. I did test other servers and they work.
Same issue 😏
That is kind of strange.
SIMBA has poor connection to Singtel (Singtel is probably the main culprit) but at least I can carry out SpeedTest with SIMBA SpeedTest server (albeit with high latency), using Singtel 5Gbps wired connection here (Intel N100 mini PC with dual 10G SFP+ ports).
Singtel SpeedTest server
Bash:
mcuee@miniroute10g:~/build/networking/speedtest$ ./speedtest -s 13623
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:     1.87 ms   (jitter: 0.07ms, low: 1.71ms, high: 1.94ms)
    Download:  5658.28 Mbps (data used: 5.0 GB)
                  1.38 ms   (jitter: 6.19ms, low: 1.01ms, high: 206.55ms)
      Upload:  4983.19 Mbps (data used: 6.5 GB)
                  6.53 ms   (jitter: 2.61ms, low: 1.82ms, high: 233.75ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/2becd27d-308b-4f13-ad47-204478f6025c
mcuee@miniroute10g:~/build/networking/speedtest$ ./speedtest -s 12687
   Speedtest by Ookla
      Server: SIMBA Telecom - Singapore (id: 12687)
         ISP: Singtel Fibre
Idle Latency:   206.81 ms   (jitter: 0.19ms, low: 206.65ms, high: 207.09ms)
    Download:  1877.30 Mbps (data used: 2.7 GB)
                312.83 ms   (jitter: 76.22ms, low: 209.59ms, high: 418.77ms)
      Upload:   318.08 Mbps (data used: 543.7 MB)
                326.41 ms   (jitter: 76.41ms, low: 215.96ms, high: 496.62ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/713766d8-78be-40e8-a5e0-997399504ed6
seowbin
Simba Mobile: First time? 🙃
their ex-staff told me, backend not that slow one :censored:
maybe to SGIX only :s34:
at some point, they are not wrong also. Nowadays seldom people (from 1 ISP) connect to another ISP, mostly connect to cloudflare, FB, youtube, netflix which are available over SGIX
those that need to connect back to some gov VPN (based on singtel ) might cry nia :s13:
Just an experiment with ping and traceroute to SIMBA SpeedTest server.
Using Singtel 5Gbps, latency is bad. It will go through Singtel STiX. So probably Singtel is the main culprit to blame.
Bash:
PS C:\work\speedtest> ping speedtest-sg1.simba.sg
Pinging speedtest-sg1.simba.sg [210.10.78.220] with 32 bytes of data:
Reply from 210.10.78.220: bytes=32 time=210ms TTL=48
Reply from 210.10.78.220: bytes=32 time=212ms TTL=48
Reply from 210.10.78.220: bytes=32 time=213ms TTL=48
Reply from 210.10.78.220: bytes=32 time=214ms TTL=48
Ping statistics for 210.10.78.220:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 210ms, Maximum = 214ms, Average = 212ms
PS C:\work\speedtest> tracert speedtest-sg1.simba.sg
Tracing route to speedtest-sg1.simba.sg [210.10.78.220]
over a maximum of 30 hops:
  1     1 ms    <1 ms    <1 ms  RT-AX86U-2D40 [192.168.50.1]
  2     4 ms     2 ms     2 ms  192.168.1.254
  3     2 ms     2 ms     3 ms  bb115-xx-xx-254.singnet.com.sg [115.xx.xx.254]
  4     *        4 ms     4 ms  165.21.193.22
  5     7 ms     4 ms     4 ms  165.21.193.21
  6     6 ms     3 ms     3 ms  165.21.138.245
  7     6 ms     3 ms     3 ms  SN-SINQT1-BO403-ae1.singnet.com.sg [165.21.138.85]
  8     5 ms     3 ms     3 ms  203.208.177.213
  9    43 ms     4 ms     4 ms  xn-lhrcl1-bo706.ix.singtel.com [203.208.183.81]
 10   183 ms   226 ms   201 ms  203.208.173.22
 11     *      258 ms     *     203.208.172.5
 12   187 ms   246 ms     *     port-channel10.core2.osa1.he.net [184.104.188.97]
 13     *        *        *     Request timed out.
 14     *        *        *     Request timed out.
 15   210 ms   209 ms   209 ms  tpg-internet-pty-ltd.e0-20.switch2.sin1.he.net [74.82.51.66]
 16     *        *        *     Request timed out.
 17   234 ms   212 ms   293 ms  210.10.78.220
Trace complete.
Using Singtel 5Gbps with Cloudflare Warp VPN: it will go through SGIX and latency is good.
Bash:
Reply from 210.10.78.220: bytes=32 time=8ms TTL=59
Reply from 210.10.78.220: bytes=32 time=7ms TTL=59
Reply from 210.10.78.220: bytes=32 time=6ms TTL=59
Reply from 210.10.78.220: bytes=32 time=9ms TTL=59
    Minimum = 6ms, Maximum = 9ms, Average = 7ms
  1     6 ms     6 ms     5 ms  104.28.0.0
  2    14 ms    13 ms    14 ms  8.29.105.1
  3    23 ms    25 ms    25 ms  162.158.160.144
  4    10 ms     9 ms     6 ms  tpg-telecom2.sgix.sg [103.16.102.199]
  5    11 ms     7 ms     7 ms  10.183.2.141
  6     7 ms     7 ms     7 ms  210.10.78.220
Trace complete.
So a work-around is to use Cloudflare Warp VPN if I want to have lower latency from Singtel to SIMBA. Cloudflare Warp will limit the speed but not too bad.
The following test is done under an Intel N100 mini PC running Ubuntu 24.04. Idle latency changes from 209ms to 43ms. Download peed changes from 2300 Mbps to 640 Mbps.
Bash:
mcuee@miniroute10g:~/build/networking/ookla$ warp-cli disconnect
Success
mcuee@miniroute10g:~/build/networking/ookla$ ./speedtest -s 12687
   Speedtest by Ookla
         ISP: Singtel Fibre
Idle Latency:   208.97 ms   (jitter: 0.24ms, low: 208.73ms, high: 209.09ms)
    Download:  2299.63 Mbps (data used: 3.2 GB)
                314.31 ms   (jitter: 76.30ms, low: 209.75ms, high: 420.32ms)
      Upload:   327.57 Mbps (data used: 563.3 MB)
                324.16 ms   (jitter: 76.46ms, low: 215.77ms, high: 496.40ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/cd018364-346c-4aa1-b77e-9048fb302365
mcuee@miniroute10g:~/build/networking/ookla$ warp-cli connect
Success
   Speedtest by Ookla
         ISP: Cloudflare Warp
Idle Latency:    43.12 ms   (jitter: 0.29ms, low: 42.87ms, high: 44.05ms)
    Download:   639.89 Mbps (data used: 791.6 MB)
                284.78 ms   (jitter: 61.95ms, low: 42.05ms, high: 1697.06ms)
      Upload:   335.39 Mbps (data used: 258.4 MB)
                 89.16 ms   (jitter: 5.49ms, low: 42.94ms, high: 333.36ms)
 Packet Loss:     0.0%
  Result URL: https://www.speedtest.net/result/c/4ee4d218-5539-46b7-97f3-25562779f757
Success
seowbin
Singtel not the one to blame
Simba never pay ERP so traffic must reach US then come back. Actually the nearest is in HKIX, can get singtel liao but you know... Budget.
Singtel always very proud of their eyeballs so people must pay ERP in sg to reach their subscribers/eyeballs.
There is an old hokkien saying, " Ai Pi, Ai Chi, Ai Dua Liap Ni" (loosely translated to want cheap, want fresh, want big). S.... is telling you , no such thing
Mach3.2
Factoring all these in, you're really better off subscribing to M1/starhub where you get globally routable IPv4/IPv6 addresses + decent peering. 🤣
For new users, M1 is a bit better now since it still offers 1Gbps and 2.5Gbps GPON based plan.
SH 1Gbps is only for Homehub+ bundle. SH 2Gbps is a dual 1Gbps service.
SH 5Gbps/10Gbps will require some investment on 10G networking stuff.
My personal recommendation for new sign-up.
https://forums.hardwarezone.com.sg/threads/singapore-isp-comparisons.6665380/
1) For existing users of any ISPs: no switching of ISP unless if you got issues or you got very good offers from the other ISPs.
2) Recommendation for new sign-up (from more recommended to less recommended)
a) M1 1Gbps plan
b) M1 2.5Gbps plan if you want to have higher speed without invest in 10G stuff
c) VQ 3Gbps plan is worth considering especially for power users. MR 3Gbps plan is also worth considering. Both are using CGNAT, so you may need to pay for Static IPv4 add-on (MR; S$51 one time charge; VQ: S$4.03 per month) if you hit into the limit of CGNAT. MR 3Gbps Gamer Plan may be a good one if you need low latency to China. Nothing wrong to go with VQ 5Gbps/10Gbps plan or MR 10Gbps plan if you want to pay for it.
d) SH 5Gbps plan is worth considering if you opt to go with the ONT
e) SH 10Gbps plan is the way to go if you need EPL or other contents bundling. Recommendation is to go with the ONT option.
f) WC 2.5Gbps plan if you do not mind using ONR and only want to have a lowest cost yet stable plan.
For SIMBA users, the better SpeedTest server seems to be 62216 CTCSCI TECH LTD, based on the reports.
It is really a shame for SIMBA that SIMBA users can not use SIMBA's own SpeedTest server properly.
I can understand bad connection between Singtel and SIMBA since Singtel is promoting its own STiX and not SGIX.
I cannot understand the bad connection between Starhub and SIMBA though. Not so sure what happens there.
seowbin
Both wants you to pay money to peer 😉
Starhub slightly less mild. 😂
If subscribe to correct IP transit, Starhub will be there or probably if clock big enough traffic, they will peer with you over IX.
I just beo, at the moment, Simba only have HE and orleng as IP transit.
seowbin
This CTCSCI tech, I must call them shifu. Their Linux optimization skill, very powerful.
Even on my mobile phone using wifi, my own speedtest server have like 600+ to 700+ Mbps download but 94x mbps upload but using them, I can hit up and down 94x mbps :s13:
I see. Indeed SIMBA has only two upstreams now.
https://bgp.tools/as/4817#upstreams
Mach3.2
i get similar results with Verizon soeedtest server. other servers doesn't test as well on phone over wifi for some reason.
can shed some light if you happen to know why?
ShaiDoesMac
@xiaofan
Do you think M1's 2.5Gbps Plan for $39.90 would be a better deal than MyRepublic & SIMBA's offerings considering that they don't utilize CG-NAT and offer direct IPv4 address out of the box without having to pay for an addon?
I am considering to switch out one of the ISP services at the end of the contract in <2 years (🥲😭😭) since I am slowly building out a list of things to host recently and now discovering looping by CGNAT with a VPS is literally the same cost as buying a proper ISP plan 🤣🤣🤣
