SIMBA Fibre Broadband
zz123456789
is simba stable? my m1 500mbps price plan is going to expire in december 2024, i am thinking of switching to simba.
lcsvince
Hmm, so bad? What kind of testing setup are you using?
SIMBA should not be so bad...
WIRED connection to Archer AX1800. Just plug and play, Never meddle with any settings.
The speedtests were done when webpage not loading. Happen very often.
tested again o_O 🤦.
Maybe it's time for me to do the layman way of resolving issue.
I have seen many decent or not-so-good test results for 10Gbps and 2.5Gbps SIMBA users. But I have never seen such bad test results.
Maybe you want to test direct connection from your PC to the ONT. If that is better, your router may have an issue. And it is probably time to upgrade your router any way.
Are you using Archer AX20 or Archer AX23? You may consider to upgrade to Archer AX72 (BNIB at about S$80 from Carousell, 1G capable only) or Archer BE230 (2.5G capable, about S$110 BNIB from Carousell).
thiamhui
Archer AX1800 only has Gigabit Ports... That's the best you can get...
lcsvince
Yes, it is Archer AX20.
Router is brand new, unopen from MR last time. Just unwrapped for use with Simba.
I shall restart my modem, router and PC later and see how. If it does not help, then i shall try using back MR router to see the result.
lcsvince
My bad... Never see the upload speed... Visually check the ports to see if the pins are ok... Or change the cables...
My upload speed always at max...
this is the test result when it is working fine, tested @ posting time
so can this conclude the issue is simba end?
Test direct connection and see if you have the same results. Make sure you use OOkla SpeedTest app. And try to change to another Ethernet cable and see if that makes a difference.
lcsvince
when using MR, my speedtests were always consistent, so i doubt the issue lies with my cat 6e cable.
As for direction connection to ONT, i have to get new longer cable (old house), hassle to dismantle my setup to bring out to living room.
anyway, thank for the help and advice.
lcsvince
done my direct connection to ONT from 2154hr yesterday.
and Simba made me record video somemore 🤦.
BTW, what is the acceptable range for upload speed for 10Gbps plan running on 1 Gigabit port ? 500ish to 900ish Mbps ?
BTW, what is the acceptable range for upload speed? 500ish to 900ish Mbps for 10Gbps plan running on 1 Gigabit port ?
Usually it will be >900Mbps for 1G port, for both download and upload.
And good ones will be >940Mbps.
Have you tried to use other SpeedTest servers?
lemonzaiii
Can share your setup? I'm still thinking about upgrading my home network.
1. x550-t2 nic for my pc
2. soft router using supermicro d-1541 board w/ built in 10gbe, using pve + openwrt
3. combination of cat5e and cat6 lan cable
4. old cheap router for wifi
if u looking for easier way, i would suggest just get a tplink EB8xx wifi-7, can be found below $400 brand new in carousell.
