1) Looks like a reasonable budget
2) If you ave existing wireless router, put it inside the DB box, carry out wireless SpeedTest result in Postion L3 and compare the results with the following two cases: DB Box door open vs DB Box door closed.
I tend to think your DB box does not block the WiFi badly.
3) Good, then probably you do not need a 10G switch.
4) I see. Maybe you can consider 2.5G capable NAS. I am not into NAS myself though.
5) Example configuration: RMB 2049 + RMB 799 + RMB 549 = RMB 3397. You need to add shipment and GST.
Price is from Asus China, you can get them from Asus China Taobao Flagship shop. 12.12 offer should be quite a bit cheaper.
If using 11.11 pricing --> RMB 1819 + RMB 729 + RMB 437 = RMB 2985.
https://www.asus.com.cn/store/gallery-476.html
ONT 10G LAN port --> RT-BE88U (10G WAN port) as main router in DB box
RT-BE88U 10G SFP+ port with 10G SFP+ RJ45 module --> patch panel --> L3 --> 10G capeble desktop in living room
RT-BE88U 2.5G LAN port 1 --> patch panel --> L1 -->TV in living room
RT-BE88U 2.5G LAN port 2 --> patch panel --> L4 -->TUF-BE6500 in Bedroom3
RT-BE88U 2.5G LAN port 3 --> patch panel --> L5 --> Bedroom 2 LAN port --> wired device if any
RT-BE88U 2.5G LAN port 4 --> patch panel --> L6 -->TUF-BE6500 in Main bedroom
6) If you need more wired device in L3, you can add a 2.5G/10G switch, around S$100.
RT-BE88U 10G SFP+ port with 10G SFP+ RJ45 module --> patch panel --> L3 --> Hasivo 2.5G/10G switch with quad 2.5G ports and two 10G RJ45 ports --> 10G capeble desktop and 2.5G capable laptop in living room
7) 11.11 pricing for reference:
