SIMBA Fibre Broadband
the starhub 5G for $29.95 ONT no more? checked last night. didn't see it.
Still there.
You may want to bookmark this page about Singapore ISP comparisons. I collect special offer hidden links (mainly from Starhub and Singtel). You just need to read the first page.
https://forums.hardwarezone.com.sg/threads/singapore-isp-comparisons.6665380/
They have both ONR option and ONT options. You should choose ONT option if you want to use your own router to its full capabilities.
https://www.starhub.com/personal/st...speed-5gbps-onr-at-2955_ultraspeed-5gbps.html (Special offer 5Gbps plan at S$29.55 per month, Nokia-XS-2426X-A ONR, also bundled with Nokia Beacon 2 to form a mesh with the Nokia ONR).
https://www.starhub.com/personal/st...speed-5gbps-ont-at-2955_ultraspeed-5gbps.html (Special offer 5Gbps plan at S$29.55 per month, ONT, you have to get your own router).
If you want to know more about Starhub 5Gbps special offer, you should go to the following thread.
https://forums.hardwarezone.com.sg/threads/starhub-ultraspeed-5gbps-plan-launched.7024290/page-98
Some notes:
No more disconnection fee. Starhub has changed that recently.
https://www.starhub.com/personal/broadband/other-charges.html
As per the report, no one time charges like NLT fee of S$61.04. After 24-months contract, the price is said to be the same at S$29.55 per month.
A few notes:
1) Starhub Digital voice is not free, at S$2.14 per month. Porting from Singtel/M1 is possible but may need some work.
2) Starhub will throttle some traffic like torrent.
3) Starhub customer service may not be that great if compared to M1/Singtel. Should be better than SIMBA/WC.
4) Right now there are issues for some customers about IPv6.
5) Indeed it is better to use your own DNS server and not Starhub's default DNS server.
5) The sign-up page can be difficult for existing customers --> basically need sign up a new service and cancel the old service on the same day as the installation day of the new 5Gbps service.
JBLwill
thank you xiaofan and hihellobye.
i still have 1 more month with M1 500mbps $30. is an instant upgrade to SH 10x for same value.
this is the best alternative of the rest already isn't it. i read all the tips and guides and it seems SH ONT is the best choice. dw cgnat and dont need digital voice but bundled is fine.
am I missing anything?
HiHelloBye
ONT is the best choice if you want to fully utilise your third-party Wireless router features
Starhub provides Dynamic IPs, and Digital Voice is optional for you
with that, this plan is purely for Internet
please continue with this thread if you have any questions
Erikku
Hi Veteran, I intend to take up SIMBA 10gbps plan for my upcoming BTO unit which is going to be ready probably by end of December.
As Simba does not give out any routers, I would like to know the recommended routers or mesh system based on my below use case.
My requirements are as follows;
1) Mainly web browsing, multiple mobile usage, Netflix, TV box 4k/MovieStreaming, not much on gaming
2) To have Network coverage for the whole house. with as little blindspot as possible.
3) Not a power user but the hardware should future proof for at least the next 4-5 years and could fully utilize the 10gbps if required.
4) PC/Laptop would likely be at suggested study area as well as all the bedrooms.
Based on my reading, I am looking at getting Asus RT-AX88U china version from taobao might fit my usage and probably need one more router to cover the whole house with wired backhaul to cover the whole house. However, not sure if I need to purchase the same model of RT-AX88U to form the AI mesh or there are cheaper alternative options I can look into.
Thank you.
Thank you.
I think you mean to say RT-BE88U, right? RT-AX88U is only capable of 1Gbps.
Questions:
1) Budget?
2) Is the DB Box big enough to house the RT-BE88U? Does it block WiFi badly (hopefully not)?
3) Which LAN port needs to support 10Gbps? Only L3? If L3, how many 10G capable devices need to be connected to L3? For example, if the PC and Laptop both have 10Gbe network adapters, then you have two wired 10G capable devices.
4) When you say future proof, what do you have in your mind?
kurt_629
funny, the simba broadband is giving a $20 off for Income customers..
but had to go down to get a code..
afterwhich, register online..
anyone got this quote to share
Jurong640
Those currently using simba 10gbps and are using home IOT products like Google Home, Tmall Genie, smartlife and samsung smartThings, Xiaomi Home.
Does these IOT things still work with the CGNAT? I'm not into using NAS at home, but want to know if these IOT connected to home network still work. Am I still able to view my webcam when outside?
thiamhui
I'm using the following without issue.
  • eWeLink (Sonoff)
  • Google Home
  • Kasa (TP-Link)
  • Mi Home (Xiaomi)
somehow, i think the best location would be at the household shelter.
1 router should able to do the job
1. But the room LAN ports will not be functional. Kitchen and service yard area will also have bad WiFi coverage.
2. For new BTO units with LAN ports in the rooms, it is good to have a router in the DB box so that LAN ports in the rooms can be functional. But usually the DB box location is not at the centre of the flat, so a second AP (or mesh node) is required.
3. If you do not need to use wired device, then yes you may want to try to use single wireless router in the central location to cover the full flat.
4. But recently quite some users post floor plans with the Household Shelter (very good at block WiFi signal) in a difficult position which makes the wireless coverage difficult for single wireless node or even two wireless nodes solution.
5. There are ways to avoid to put the main wireless router in the DB box.
1) use a wired router in the DB box. Some users like ONR due to this reason, but then ONR has its own issues.
2) to have two LAN ports next to each other in the living room (or other rooms where you want to put the main wireless router) and then add a switch in the DB box. Unfortunately most of the BTO flats have the two LAN ports in the living room far-away. You can fix this during the renovation phase but most people may not know this trick.
3) Use two VLAN capable switches. This can be expensive for 5Gbps/6Gbps/10Gbps plans.
Please refer to the following FAQ for the above three options.
https://forums.hardwarezone.com.sg/...home-networking.6653421/page-3#post-149431568
Jurong640
  • eWeLink (Sonoff)
  • Google Home
  • Kasa (TP-Link)
  • Mi Home (Xiaomi)
Thanks. I'm using ewelink sonoff too, glad that it work.
How is simba fibre for you so far? I read about downtime. Any lag so far during night time?
