SIMBA Fibre Broadband
XiaoJinLing
best practice:
only terminate once your second ISP is up & running
if you're a risk-taker, then by all means terminate first lol
Ok. Thanks for the advise... so if my singnet last day is 16may25... so i arrange 1month before (mid apr??) should be best??
Anyway I dunnot about all the setup... simba will help to do?
HiHelloBye
also can...
not too sure on Simba's SOP, but from what i heard it's plug & play
basically, your unused FTP Port will be for SIMBA and from there, you just plug into their ONT
luei74
Simba procedures:
A. Online sign up, choose FTP activation appointment date.
B. Acknowledge email from Simba, choose ONT collection date and location, Simba provides a few ONT collection points. Mostly at those Ah Beng shops that selling their mobile SIM card.
C. NLT team will come to check and activate the port. For my case port 1 used by M1, port 2 never activated before, there's some hiccups during the activation process, good to be at home with them, make sure after activation you got a good signal in dB.
D. Once activation process is completed, you can proceed to connect the ONT and your Modem/Router to set up the connection, it's pretty plug and plug process.
E. You can request Simba to set it up for you too, they charge $39 to set up for you.
drache
Simba procedures:
How to make sure we got a good signal in dB?
Do we need to wait for NLT installation before installing the ONT, or the sequence doesnt matter?
Thanks!
luei74
Thanks!
If your second port has yet to activate, I think it is good to be at home to work/monitor them.
But if your second port already been activated and using it now. The connection should be there, under this circumstances, you no need to be at home with them.
After the splicing at their end ( which I think), they will use the optical meter to check for the acceptable dB strength. Below is my second port measurements.
slash
Thanks @xiaofan for the hidden links and analysis.
I was rooting for Simba when it announced 2.5Gpbs @$20. But then my contract ended that time my area wasn't ready.
Now that it has 10Gbps, but from the bros mentioned here, the long maintenance hours 12-6am is unacceptable to me, that's mostly the time I needed the connection.
And also the movie streaming (from certain countries) might be slow, also unacceptable.
So in I think SH 5Gbps (no frills, no additional setup cost) is more suitable for me. Though the 24mth contract sucks... guess by the time contract ends, WIFI 7 routers will be more affordable or maybe by that time faster speeds would have emerged (maybe 30Gbps for $30?)
Anyways, thanks for all the feedbacks and comments everyone, learnt alot here!
Hamlau
Hi I'm sorry if this was already in the thread but may I ask: Since Simba BB don't have fixed IP add-on, will it be a problem accessing your personal streaming server (e.g. Plex) and your smart devices from outside? I apologise if it's a stupid question ヅ
sglandscape
You'll need something like Tailscale. SIMBA uses CGNAT so unless you have ipv6 it'll be a challenge.
KSSL13
Hello. Just to share. My simba NLT activation was today between 130 to 7pm. By 4:22pm I received simba email notifying me that my NLT has been successfully activated. I plugged in my simba ONT, power on, connect my ASUS router, power on…. WOW, my internet is up and running!!!! Seamless activation and ONT was plug n play. Don’t need to pay for $39 set up. Thanks simba. I don’t have a laptop to test the true internet speed but with speed test on my iPhone 16 pro max I am able to get 3x the speed of what I used to get with M1’s 1Gbps fiber. Happy!!! Thanks
