SIMBA Fibre Broadband
tewem
Yes, I did removed the plastic cap on both ends before plugging in. SIMBA support informed that their Network Team has confirmed that the ONT is online, with all parameters functioning normally and the optical reading well within range.
I just bought the eero max 7 router and it still doesn’t work. I guess I will request for them to troubleshoot and setup my router at my home
I guess it may not be your router's issue, could be a few factors:
1) Simba ONT device faulty or Network cable faulty?
2) Connection not done correctly?
3) PC / Laptop not configured properly?
May I know which location you live in?
CISC
I may be biased against SIMBA/WC/Singtel, but you can check out my reasoning here (just the posts in the first page will do) and you can come out with your own conclusion.
https://forums.hardwarezone.com.sg/threads/singapore-isp-comparisons.6665380/
There are two good offers from Starhub if you do not know yet.
1. Starhub 5Gbps offer at S$29.55, with Nokia XS-2426X-A ONR
https://www.starhub.com/personal/st...speed-5gbps-onr-at-2955_ultraspeed-5gbps.html
You can consider the Nokia XS-2426X-A ONR as a 10G capable wireless router (AX6000, with one 10G LAN port and three 1G LAN ports). You also get a free Nokia Beacon 2 (1G capable only as a free mesh node.
This has superb value for average users who do not mind using ONR and do not want to spend more money to get new wireless routers. If you need more mesh nodes, you can still get extra Nokia Beacon 2 node at cheap price from Carousell if required.
2. Starhub 5Gbps offer at S$29.55, with XGS-PON ONT -- you have to get your own router.
https://www.starhub.com/personal/st...speed-5gbps-ont-at-2955_ultraspeed-5gbps.html
The ONT promotion will mean you buy your own router (for users who do not like to use ONR). This offer is also of very good value, especailly since you can get TP-Link HB710 from Starhub at S$192 or TP-Link EB810v at S$360. TP-Link HB710 and EB810v are both service provider models but it should not be an issue if you stay with Starhub.
You can of course get your own router as well.
Hi @xiaofan ,
Seeing your comment above - I am hoping if you can clarify the below.
My household is with starhub BB. I am looking to purchase HB710 from Starhub and sign-up with Simba for my aunt who lives alone.
I'd appreciate if I can please confirm Starhub's HB710 works out of the box with Simba's ONT?
Thanks in advance!
Hi @xiaofan ,
Thanks in advance!
Yes it will work but I myself will not recommend to use HB710 outside of Starhub network.
HB710 is a TP-Link Service Provider model which is more or less tied to Starhub network. There are reports that users using it with other ISPs are able to get FW updates but I have not confirmed that finding myself.
CISC
Many thanks for the quick response, I am not too fuss about FW update. If it comes down to issues requiring FW updates I can always bring the router home for further troubleshooting.
just looking for a cost-effective WiFi 7 router that works with Simba ONT.
This is very promising.
Thanks again
Thanks again
Yes, I think your plan will work.
FW updates for TP-Link Service Provider Models are actually important. There seems to be slower FW updates and more bugs with the TP-Link Service Provider models as a result (and less features like no Wireguard support) compared to consumer models.
TickTechToe
So how is it? Any update?
KSSL13
I am planning to sign up simba’s 1gbps home fibre broadband, but there seems to be mixed experiences here. Any advice if I should go for it? What about ONT installation? Should I pay $39 to let the expert ensure internet connectivity? Or is it really simply plug and play? Thanks
TickTechToe
For me is plug and play.. save the $39...
Just for your reference, you can read the first four posts of the Singapore Comparison thread and come to your own conclusion to see which ISP to go.
For low cost plans, now there are many options --> Post #4 in the above thread.
I will usually recommend Starhub and M1. But I understand people may have good reasons to go with other plans.
Updated: 24 Jan 2025
Some notes
1. It is good to have more competitions with around S$30 (effective pricing) plans from the ISPs.
1) Starhub 5Gbps offer at S$29.55 per month. Nokia XS-2426X-A ONR (AX6000 wireless) option with one free Nokia Beacon 2. Very good value for average users who do not want to pay anything extra on routers.
Recontract offer is at S$30.37 per month with the same ONR+Nokia Beacon 2 (some users got two Nokia Beacon 2).
2) Starhub 5Gbps offer at S$29.55, ONT option without router. Very good value for those who do not want to use ONR but their own router.
Recontract offer is at S$30.37 per month with ONT+TP-Link EX510.
3) M1 6Gbps offer with two-pack of ZenWiFi BT10 at S$59.90 per month. If you value the two-pack of BT10 at about S$720 or more, then the effective price is at S$29.90 for 6Gbps no-frills plan. Some users are able to sell the two units at about S$800 to lower the effective price at S$26.57 per month.
Recontract offer may be even better for 6Gbps plan. S$32.90 per month with free Archer BE805, or S$44.90 per month for a pair of ZenWiFi BT10. If selling the Archer BE805 at S$240, the effective price is at S$22.90 per month. If selling the two BT10 at S$720, the effective price is at S$14.90 per month.
4) Singtel 3Gbps plan at S$29.90 per month for selected new customers only (Singtel mobile customers who want to switch to Singtel for Fibre Internet).
Existing users may get 5Gbps offer at S$29.90 per month (updated on 24-Jan-2025).
https://www.singtel.com/personal/products-services/broadband/eform/recon-dm/fibre-5g
5) SIMBA 10Gbps plan at S$29.99 per 30 days.
6) WC 2.5Gbps plan at S$24 per month (very good for recontract users). New users need to pay NLT charge of S$61.04 and installation charge of S$54.50 and the effective price of S$28.81 per month.
7) WC 10Gbps plan at S$28.99 per month (very good for recontract users). New users need to pay installation charge of S$54.50 and the effective price of S$31.26 per month.
8) VQ limited time promotion of 3Gbps plan at S$29.98 per month (no frills plan).
Then we have legacy M1 500Mbps and Starhub 500Mbps plan at about S$30.45 per month for those users who stick to the two plans (no need to recontract to continue the same pricing).
rat3dr
Same! Was just wondering, since I'm currently still on M1 FBB, will simba be activated on the other port of the NLT?
XiaoJinLing
My singnet current contract ending 17may24... if want to get this cheaper simba... wait I jus cancel singnet then get simba to come n install? Or simba can come earlier n i will just pay some overlapping period.
Simba right now come with free installation n router?
HiHelloBye
best practice:
only terminate once your second ISP is up & running
if you're a risk-taker, then by all means terminate first lol
