SimplyGo with Visa
Imhthc
Not talking about the claim. But the stupid card cannot use since missing exit on bus. Stupid right? Must go control centre reset?
I thought have to change new card issued from bank. Last time the control station keeps telling me is the bank issue Ended up requesting for a new card.
PetPet
Moderator
Moderator
No such thing.
Could be failed due to a variety of reasons. Such as card is locked because you didn’t input the PIN correctly at the ATM etc etc
But definitely not because you didn’t tap out.
Edit: Also if you fail to tap out and the system is unable to “estimate” the location you alighted. A full 2$ will be deducted.
hyperbole
No such thing.
what do you mean no such thing? i encountered it, you didn't. doesn't mean there's no such thing.
my card isn't locked. i used my smartwatch to tap out at bus and failed, next morning i was charged the full trip's amount, but i could not tap in again at mrt. i got 'card failed' error at more than 1 reader.
i used the physical card with no issues. i later deleted the card off samsung pay and re-added again so it read with a different card number and managed to use it again.
hyperbole
i used my smartwatch to tap, so i deleted off the card and put in again so it assigned another virtual number then ok already. definitely not an issue of physical card spoilt.
don't understand why there's this problem since they already deducted the full trip's amount from my cc and charge went through successfully. there shouldn't be any reason for 'card failed'.
happened to my dash too, but that one i can't do anything to it, so i stopped using for transport.
fr33d0m
check with your bank. It is very likely that SimplyGo can't deduct money from your account so it blocks the card from any further transactions.
hyperbole
the amount deducted fine. i received the sms from the bank on that transaction. as did the transactions on my dash. few weeks later, still cannot use after payment went through.
piaget
What is the best credit card for simplygo now? Excluding those card with temporary promotion.
hyperbole
I'm using DBS live fresh cos they give 5% and I'm already using this card for my daily spend
chopra
simplygo if tap bus after alight mrt, it says bank usage. no way to tell if it's a "transfer".
linuskltan
I'm using Bank of China Qoo10 MasterCard. 20% rebate on SimplyGo, with min monthly $600 spend. I'm using BOC SmartSaver.
ceestudent
For uob one, does the simplygo transaction counted toward usage to earn the cash rebate?
