chunlianghere
- Nov 24, 2005
but weird , i input the settings in my asus router, i can get IPv6 now![]()
yup.. tat is weird. w/o going to singtel shop to apply for ipv6, yet can get ipv6.
Didn't call singtel, but in the aztech dsl7000grv singtel admin page, the details for ipv6 support are already filled in under IP Tunnel. Didn't fill it in myself. Disabled by default though. Enabling it makes opening sites take quite long, so I disabled it again.
I have no problem enabling it on my asus N56U. Still load as fast. Maybe you can screenshot the settings let us see
i called them to say i wanna activate ipv6, but they say its activated by default, no need pay 10 dollar, i followed the asus rt56u configuration, ipv6 test says fail, but say my ipv6 configuration is correct
is it normal, when i off ipv6 i can get 500+mbps at singtel speed test
when i on ipv6, i only get 200mbps at singtel speed test
Yes. You log in to Onepass and then under the fibre connection entry there is Show Details there is a list of addons. IPv6 should be there.
Finally, managed to get IPv6 running.
However speed test at speedtest.net is at 1/2 speed I get from IPv4.
I get better speed using other servers.
which other servers u mean?
Using Singapore, Starhub, Telin, SGIX servers.
