Sony 1000xm3
D3st1nY85
Anyone experiencing the ambience control not working as intended? I tap on my left earpiece and a sound is produced but the mode is not rotated. Sometimes it work and most of the times it doesn't. Any fix for this?
chesterqw
check the manual again on how to change the noise cancellation mode ;)
edit: this thread is for the headphone btw not the earphone
DualForm
Anyone having issues with sound skipping? It only occurs when i move around and my phone is in my pocket (Note 9). When not moving i don't have this issue, using spotify for music.
Apparatus
AV One just called to say the Dekoni Elite Hybrid suede replacement earpads is available now as the stock just arrived.
Those interested can buy from there
dreamwalkz
=:p =:p =:p
The suede earpads, how do you remove the stock pads and put it on?
Edit: found that it comes with the plastic attachment bracket. Looks quite hard to remove leh..
Sent from Xiaomi MI MAX 3 using GAGT
Apparatus
No problem lah. I just followed instructions as given in youtube can leow
Gloom me
Please be careful with the blue plastic tool provided by Dekoni.
Mine broke while removing the original pad. Luckily I have my ifixit toolkit.
Apparatus
The small tip is no use wan. Only the handle is useful. You can also use the handle of a metal teaspoon for the job
