Sony Android TV
syak_88
Got the 55x9000f. Any1 know if yas107 soundbar can sit in between the tv stands? Planning to get that soundbar if i can push it a little inside.
petetherock
Moderator
Moderator
https://www.oppodigital.com/blu-ray-udp-203/UDP203-firmware-60-0601B.aspx
Added the Dolby Vision “Player-led processing” mode for compatibility with recent Sony Dolby Vision TVs and firmware updates.
Added the “Dolby Vision” mode under the HDR Setting menu, which allows the player to convert the output to Dolby Vision when possible.
Added the “Dolby Vision Processing” setting under the HDR Setting menu. This setting allows customers to choose whether Dolby Vision processing is handled mainly by the TV or the UDP-20x player.
Added MQA support via the USB DAC In for the UDP-205 players. (More info can be found in the “USB Audio DAC Firmware” section on the UDP-205 support page.)
Added the “Up-Sample DAC Input” setting under the Audio Processing menu for the UDP-205.
General fixes and disc compatibility improvements based on recent and upcoming UHD Blu-ray releases as well as user-submitted samples.
destan
Just wanna check if you guys using Sony default video player in the Sony TV to play 4K media content from your USB drive?
Sent from Samsung SM-N950F using GAGT
xiangzeng
Im aware of this but I'm looking for a soundbar with integrated sub due to space constraint.
I suggest that you get the dimensions of the sound bar you want to buy and also the space at which you want to place the sound bar. Then, compare and the wiring routing. This will clear out the myth and waiting for answers. I always do this method and get things going.
xiangzeng
Yes, I use the sony video player.. It does not recognise the sequence of the files and thus will not play, for example, a series of videos with numbered file names. So, I have to stop, go back to search and select the files and play them. Not ideal player but it works.
estrique
I’m considering to buy either a smart TV or android tv but don’t know which is better. If Sony android tv, should I go for W800F or 8000e series? Mainly only use for watching dramas in my room, 43 inch. Any advice?
Ed.YEO
Any difference when watching soccer on miotv box on x8500f and x9000f?
你嘅MIO機頂盒如果輸出1080i高清畫面,就要睇你電視影像處理器有無2k畫像提升(upsaling)至4k畫面功能嘍。。。
xiangzeng
FHD - 43W800F S$999 or 4k /UHD - 43X8500F S$1,349 all at best denki.
yellowtang67
Has anyone managed to get the Google Chrome to work on the Sony Android TV. Tried a few methods shown in you tube, but cant seem to be able to use it, although I can see the app in the main TV menu. any help will be appreciated
destan
Has anyone installed Amazon Alexa on Sony android TV.
HMAN
what exact problem are you facing ? I have been using Chrome browser with my sony Anrdoid TV for more than 2 years..
yellowtang67
I have manged to get it working. On some websites, there are these annoying advertisements which tend to open in a new window as opposed to opening in a new tab. Any way to overcome this? I have checked that pop up blocker is enabled.
riieee
Hi all, is $3299 price good for 65X8500F with wall mount?
Or any better deal out there?
blueye
I need advice too as I just bought Sony tv. Chrome browsing experience is slow in general and I didn’t expect it to be of tablet, computer standard.
Streamline videos from websites is painful. Slow, laggy, set up ad blocker but no use.
When I use laptop on the same websites to load video...no issue. So my solution is to use hdmi from laptop to tv.
Smart TV not very smart after all. My friends claim Samsung web browsing is faster. Processor difference?
