Sony Android TV
Kwein
why use chrome to stream video when there's proper app?
so far my experience is fast and smooth
I need advice too as I just bought Sony tv. Chrome browsing experience is slow in general and I didn’t expect it to be of tablet, computer standard.
Streamline videos from websites is painful. Slow, laggy, set up ad blocker but no use.
When I use laptop on the same websites to load video...no issue. So my solution is to use hdmi from laptop to tv.
Smart TV not very smart after all. My friends claim Samsung web browsing is faster. Processor difference?
Kwein
i've installed terrarium, mobdro, Freeiptv, Megabox HD
i just backup my mobile phone apk and installed into the tv, simple and straightforward
Dramacool for Korean serial got no app. Google play store for tv limited...not like mobile phone.
Pl8888
My Samsung ks9000 tv browser also slow , I think basically tv browser quite slow . I don’t use browser on my Sony w800c also , I use apk apps .
Korea drama You can download rss player and setup from there . U need to sideload the apps , not from Google playstore .
ablue15
Hi Bro,
How do you download RSS player on android tv?
I'm using Sony X90F can't download.
I installed apk also cant install it. :(
thomasoon
Hi Bro,
Try this.
From Facebook New TV Box SG page.
rss player for Android TV ver 1.0
https://my.pcloud.com/publink/show?code=XZT6hY7ZzoXhE9v5bVkE1WLpRqEzA8F9LNnV
forests_gump
Actually android tv or just normal tv with a android tv box better ?
Android OS on TV - has to serve 2 major function:
~ TV hardware OS : Tuner selection, HDR decoding, video color compensation computation to match the LCD hardware, etc.
~ Platform to run Android app.
Different TV makers ends up own unique implementation, over as time there are 2 issues:
~ TV maker abandon OS upgrade support - stuck with old Android OS
~ Slow down in performance as app installed increase; sometimes so bad even impacts TV hardware.
So sooner or later you will need a new android tv box anyway, cheaper to replace box anyway.
Wld not put much consideration if TV OS is android or not; TV PQ shld be major primary factor to consider instead.
cscs3
When TV maker abandon OS upgrade, user has to worry about security patch/fix too.
popdod
Has anyone managed to get the Google Chrome to work on the Sony Android TV. Tried a few methods shown in you tube, but cant seem to be able to use it, although I can see the app in the main TV menu. any help will be appreciated
For streaming videos, i just use laptop and Google Chrome to cast it.
save alot of issues of pop-up ads.
no need use hdmi.
Kindovic
is there anyway to bring the tv contents to your mobile phone (samsung)? just like the opposite of casting ur phone to the tv....
i think samsung tv got this feature
moron+genius
no need use hdmi.
If Sony tv support miracast n ur laptop is win10 u dun need google chrome 4 casting. In laptop under Connect u shld b able 2 c the tv listed as a device if both r on same network n u connect to it den u casting wirelessly
ablue15
ablue15
Actually i previously downloaded Phoneix OS to dual boot my pc.
Its an android platform (aka hp) on your pc/laptop.
Its kinda fun to play with it as u can also play games on it. :s22:
However, not all apps work with it. Have to trial & error.
dreamerzz
any one know how to lock the language in chinese on channel U cos every time when i set to chinese... switch channel or off the TV and on again it will goes back to korean language on korean drama..model R500C
dantom04
Hi all, I’m using x8000e series tv. Anyone with the same tv able to use a wireless headphone to work with the TV? Seems like this model don’t have A2DP, can’t use Sony Bluetooth headphone at all :(
