- Mar 9, 2004
G series is here!
G series is here!
Are u referring to the Master Series ? Z9F model ?Harvey Norman weekend Sony promotion.
65” OLED with acoustic panel $6899 if I remember correctly. Plus free PS4. Went browsing just now at PP while waiting for Wife.
The acoustic panel is amazing. Sounds good and got substantial bass somemore.
First time I see such technology. Amazing.
Sent from OnePlus ONEPLUS A3010 using GAGT
Hi my KD55X9000F has some issue turning on with the remote control or direct from the On switch from the TV.
I can only turn on the TV after repeated try the On button on the remote control. Once its On, it will show the Sony logo and Android logo, seem like it restarted the system.
Is this normal?
Fresh start? Take note Android TV startup is like PC, you need to let it startup after you turn on the main power.
If you try to switch it when it is booting up, Sony logo follow by Android will show.
Such TV are not like older Smart TV where you need not wait for it to startup.
Z9F is not OLED.
Is actual QLED technology.
Yes, fresh start everytime after a day.
Press Switch On button on remote control, nothing happen, no light indication on the TV, after repeatedly pressing the On button, the TV light indication below the Sony logo lights up, then followed by a fresh start with Sony and Android logo.
After it starts up, I press TV, its fine. Then afterwhich, I off the TV and On the TV, it does not go into the fresh start mode and it work like a normal TV.
Fresh start mode only happens after long period of not using (for example, last night switch off TV at 10pm, this morning at 10am, it will go into fresh start after switch on TV)
Is this normal?
Normal to me, you have to give it few min to boot.
Did you off the main power switch in the night?
Really?? I need to press the "ON" button on the remote control a few times, before the light indication below the Sony TV is on..
No, I did not off the main power switch at night
For the price it was going for esp towards the end, the quality is solid. Some may say can’t compare to OLED but firstly its a different technology & secondly the price difference.One month on and the X9000F is out of this world. Coming from an older Sony tv, the brightness is on another level. Chose this for the FALD panel and image processor. Even gaming on it on Xbox one content is fantastic.
Noted with thanks! Meaning if OLED is out of my reach (price wise), can consider X9000F? Saw in Sony SG website that X9000F series has 49", 55", 65", 75" and 85"! ...![]()
