Sony Android TV
86technie
Was wondering what is the diff between 8500 n 9500? Is there is 9000? How big the diff?
Big difference between the two, however consider your source.
If mainly youtube, download movies or streaming X8500 will do fine.
X9500 have better image as well as support for Dolby vision.
For X9500 to shine, recommend to play Blu ray titles with Dolby vision.
Consider your source first before deciding what to invest in.
mamboeidos
My source like wat u said or YouTube, netflix, streaming or played from my desktop. Also gaming on Ps4 and switch. Watching movie also of cos
So the diff of the X1 chip, contrast, motion flow hardware and sound processor dun matter much since I am s
Doing the above and not much of a blue Ray usage?
petetherock
Moderator
Moderator
The chip matters
But you cannot make a purse out of a sow’s ear ..
86technie
Oh... OK unless Blue Ray TV if not its not worth the jump from 8500 to 9500 with the content I am play on my TV rite?
Yes, don't get me wrong you still can consider X9500G.
But if you want to shine, play blu ray disc movies will get the most of the out.
Unique.Melody
btw, both 8500F/G and 9500G have X1 chip. just that 8500F/G uses X1 chip and 9500G uses X1 Ultimate chip. Only 2018 top line Sony models uses X1 Extreme Chip.
to simplify things in term of power of the different chip:
X1 Chip < X1 Extreme Chip < X1 Ultimate Chip
if you have cash to spare, can go for the 9500G for future proofing, maybe in the long run you decide to watch 4K HDR content, at least you can do so. That is not saying that the 8500F/G cant do 4K HDR content. Its just that it doesn't look that great for HDR content on the 8500F/G
mamboeidos
Yup. The chip in 9500g better than 8500g. But then 9500g dun have 49..only 55 and my room currently using a 50 which I feel cannot get any bigger if not it like sitting first row in the cinema.
But for 2018 F model I rmb 9000f or 9500f have 49 rite?
yooooz
Yes 9500 is definitely better image. I think you should ask yourself if you are a person who pays attention to details?
In a movie, does a darker spot in a scene where you can see the items matters?
In concerts, when the spot light down you can still see the items matters?
In a food video, does the prawn where you can see a more defined red and white matters?
If all these don’t matter, get the lower end model.
Ask the salesman for a compare side by side. The 9500 really can see the details. But when you have no comparison at home, does these details matter to you?
ChaosPaladin
planning to get a new TV for the living room of my new place. width of the living rm is around 3m. i am guessing 55" to 65" is sufficient based on the optimal viewing distance.
i am watching mainly netflix and downloaded movies. i will be playing ps4 and switch as well
shld i get x9000f, x9500g or x8500f
Unique.Melody
there is no 9500F. The current 9500G replaces the Z9F of 2018.
the highest was the 9000F in 2018 for LCD FALD. for 49" i feel the 9000F was the best LCD you can get for the money at the moment. Even in 2019 I dont see any TV able to beat it overall (in the 49",50" category). If you're able to find any KD-49x9000F on the market, i would say it'll be a good investment.
Unique.Melody
if you're able to get x9000f, then go for it, since its cheaper than the x9500g. Quality not much difference for you to go WOW. Whereas the x8500f would be much of a difference compare to the rest.
Then again, if you're on a tight budget, go for x8500F/G since you'll be using it in the living room, presuming it will be a well lit.
86technie
Yes, FYI 4K TV recommend size above 50 than you can see difference.
Below that difference is subtle, that is why if you notice that
8500G.
If above 50 inch, the specs are different than those below.
Above 50 than Dolby vision is included.
X9000f have 49 inch but I don't think you can find that model
any more.
mamboeidos
Yup no 9000g that's y asking 9500g n 8500g big diff....maybe today go causeway point see if they have 9000f.
Read it few pages up a few bought 9000f but the bigger screen and was happy with it.
ChaosPaladin
guess i shall go compare 9000f and 8500f/g and see whether i can distinguish the differences. anywhere with good price now for these 2 models?
as another forumer mentioned, wat is the promotion at HN now?
Jo1818
Best Denki still have 55X9000F but it’s display set. If you don’t mind.
