TV has to be OFF in standby mode 1st. Then pressed the sequence to power up.
It was turned off. Went through the sequence also. Didn't work.
Does firmware play any part in this?
Version
mine is 5.0.2
You said good for 720p but no good for full hdb. Perhaps Sony wireless not fast enough.can't be. playing on my PC screen no jerk....but stream to the sony TV , it jerks alot....
stream to my LG TV also no problem ....so must be Sony TV problem ?
What if you copy the same file onto a thumb drive & playback on the TV?
Based on what you have tried so far, I still feel that your wireless speed for streaming may not be good enough. Youtube is known to have reduced bit rate compared to the original video (you have verified). I called this a data compression because those full hd files that I uploaded all have the file sizes reduced. In one case it was from 110MB to 15.8MB. Looking at this from a different angle, it means a reduced data rate for youtube video. So you can stream it well while those files with higher bit rate were not so good. I believe frame rate has no effect on the streaming. It is the bit rate that counts.I downloaded a 1080 youtube file and it manage to stream properly to the x8300C.
I wonder if there is something to do with the file.
the youtube vid has a data rate of 4151kbps while my other vid is twice or 9000kbps.
bit rate of youtube vid also 1/2 that of the vid that is not streaming properly.
frame rate 23 vs 29.
I m not sure if these are causing the jerky problem.
The Sony eSupport provides information on how to test the speed of your Internet connection. This may be useful to verify your connection speed.
Edit: all along I have assumed that you are using wireless for streaming. If you are using wire, you may have to check the lan cable.
If I were you I would have called Sony. Not sure if they will bill you if they found nothing wrong with the tv. But I know Samsung definitely charge for service rendered even during the warranty if there is nothing wrong with the set.I don't think there is anything wrong with my LAN cable.
When connected to my laptop, I am able to get gigabit lan. but when connected to my Sony X8300c, I am only getting 100MBPs.
I also have 2 LG TV connected to the network. One LG TV is connected to the network by a powerline adaptor (which has speed of less than 100mbps). I tried streaming the same full HD video from my NAS to this LG TV, again, stream smoothly, unlike the Sony TV which just jerk and can't even finish playing the video.
So that particular video when stream to 2 LG TV has no problem, but stream to the Sony TV, has problem. Should I call Sony centre ? I was going to get 2 more Sonys but I am afraid there will be the same problem when streaming high data rate videos.
media server which platform ?? any streaming apps ??I downloaded a 1080 youtube file and it manage to stream properly to the x8300C.
My order of W850C from gain city 1 month liao, they still can't deliver yet... really is
@minute_me
I don't think its the limitation of ur connection, its the limitation of the transcoding hardware.
I'm running kodi on my w800c wireless-ly, it can't do any 10bit mkv (bad rendering, stuttering badly or it just doesn't play), but I can play 8bit mkv to ~9k bitrate perfectly fine (anything higher, it will need buffering time every few min).
From ur previous posts, i see u are using nas, if ur nas have satki cpu, u can try using plex, that way the transcoding will be done on ur nas's satki cpu, and tv should be able to play.
I think u need a 414+ or 414play to transcode those more hardcore format.
U upload the vid i see if i can play or not lor.
I think old tv uses dedicated processing chip to transcode these videos, and android tv uses arm processors which do a lot more than just transcode, but isn't that great at doing just transcoding??
I don't think Sony used a good arm processor for their tv also.
Maybe u can try streaming the video on ur android phone? since it uses arm processor as well.
If it doesn't work on ur phone as well, then ur vid format is just too op for mainstream arm processors.
Video encoded format plays a big part also, I can play 8bit mkv with 9k bitrate, I can't play 10bit mkv with 1k bitrate.![]()
anyone knows whats the latest deal for w800 50"? still able to get below 1.5k with the additional sony gifts? care to share where having the best deal. intending to grab 1 this week. thanks.
Try mustafa.
...The Sony eSupport provides information on how to test the speed of your Internet connection. This may be useful to verify your connection speed...
any owner of KDL-800C guide me on how to use the PIP feature.
when i click the PIP button on remote
"to use this feature, a system software update is required, please refer to reference guide"
I'm using the latest firmware PKG2.311.0010.PAA
