Sony Days 2015
Kvicez
Best Denki was selling KDL48R550C at $799 (u.p. $1099) over the weekend. Is the KDL48R550C good? Are there any known problems with this model?
I intend to replace my grandma's 32 inch Samsung TV with this model so that she can enjoy better. No need for smart TV features or anything - just a dumb TV will do.
Thanks!
nomoney25
I guess the price will be the same promotion price during the June/ July Promotion.
FREE PS4 for all the 4K 65 inch and above
kun1he2
Doubt anyone really needs this feature... but new Android firmware with Twin Picture support is out ...
SBC
Is W series with Android a good choice? Looking at 55"
How is the PQ for TV program?
Using Pioneer Plasma now.
ralliart12
My thumbdrive got corrupted by the X8500C again (2nd time already). I didn't even launch any app that was using the thumbdrive during this specific session.
Will suggest any owners to use only thumbdrives that one can afford to "lose" data on with this TV. Heng I learn my lesson the first time round & didn't put anything critical on the thumbdrive.
cscs3
Thanks!
HN is offering Samsung 40JU6000 at $799. Is a 4k model. However only 40in. 550c is not a smart TV, so do consider this if you need a Internet function.
kun1he2
How to activate? I can't find it in the Action menu.
Hmm, make sure that you are viewing one of the HDMI inputs and check if it appears?
Note that the option is not in the first column of options - it has its own column (iirc, it's the 3rd column on my TV).
Milo-Dino
between X8000C, X8300C and X8500C got any quality difference?
quite tempted to settle just for X8000C
nomoney25
Only x8500c will have hdr support thru a future firmware update. 55 65 75.
X8300c is the basically like 55 inch x8500c but as in smaller size limited to 43 and 49inch. All using edge lit. Only 65 and 75x8500c using direct lit.
For x8000. a cheaper but dont have the full features that found in x8500c
ddwmk2002
oni x8500c have the triluminious display. side by side I notice x850c has slightly more vibrant and sharper images. but not by lot thou. see for yourself to justify in the price difference. I have the x8500c for a while now and still quite please with it.
Kevin10
Ia Sony much better than LG? Have been looking around but couldnt decide which brand and model to buy.... Any tips?
Me too..but then everywhere I go , the salesperson will recommend me LG.. so hor, I will choose Sony instead. :s13::s13::s13:
hayashl
Hi Guys, which model would u recommend for a budget of $2500? Also as for the Sonydays free gifts, how do you redeem?
