Sony Days 2015
ralliart12
Hmm, make sure that you are viewing one of the HDMI inputs and check if it appears?
1 of the 2 inputs must be HDMI?
Can the following combinations work? 1 USB & digital-broadcast TV? Native YouTube app & digital-broadcast TV?
nomoney25
Ia Sony much better than LG? Have been looking around but couldnt decide which brand and model to buy.... Any tips?
I bought Sony tv as i have been using this brand for 20 over years and no one needs to tell me what brand i should buy. But if u look at Sony facebook , U will still see people complaining about their tv too..What comes out good for me doesnt mean it will be good for other.
Last time i owned a goldstar crt tv , it last about 7 years but unlike my sony crt tv, it lasted about 10 years. My experience with Sony is good, that why i always consider tv as my prefered choice.
How i go for a tv, mainly i decide based on
Budget? (Min $800 till Max under $6k++)
Size? (40, 46 55, 65 or 70 above)
Feature (4k or FHD, HDR support. Smart tv)
Panel (VA or IPS, 3D or non 3d? )
vpromax
Thanks for your tips. When i shop around i notice that the salesman always push for LG or samsung. Hence till now couldnt decide which brand and model to get...
kerrying
Hi Guys, which model would u recommend for a budget of $2500? Also as for the Sonydays free gifts, how do you redeem?
Besides budget, what other criteria you may have in mind? For example, UHD/HD, 3d/no 3d, going to play games on it/or not, type & number of input connections you need, level of picture reproduction quality that you can live with (from "very particular, color must be accurate.." to "can watch can liao")?
Generally, I would suggest consider putting the budget into screen size (go big), rather than fancy features you may or may not use at all (internet connectivity, android tv/smart tv platforms..).
For Sony, 60W600B (this is last year model, though, if I remember correctly), 55W800C (2015 model), 49X800C?
http://www.sony.com.sg/microsite/sonydays/asset/pdf/bravia-chart.pdf
For Samsung (the model naming can be a little confusing and different in different regions..), maybe UA60J6200, UA50JS7200?
hayashl
Thanks bro for the reply.
KD-55X8500C (55”) is this a good buy? LG true black feature worth it?
pgem
For the 55 inch, what are the differences between the X8500C or X8000C? Which is a better choice?
Thanks.
Kevin10
Yesterday was at Jurong Point Courts..
55X8500C - Selling @ $1994 (FOC 3D Glasses,Bluetooth Keyboard)
55W800C - Selling @ $1399 (I think same as above for FOC items)
But the terms are:
Terms - Need to lend them for 2 weeks to display before you can collect.
Nickttmseller
Guys I am currently looking for a 49' inch TV, thinking of getting a SONY KD49X8000C, anymore recommendation ? My budget is below $2K.
Thanks.
CatLuVer
Thks for the advice. W600B looks good also
