Sony Days 2015
ralliart12
GoogleCast not working
Did anybody's X85C's GoogleCast capability get broken after the latest firmware update?
Mine's broken, & I'd verified that my mobile device that I was casting from, is on the same network as the TV.
kun1he2
Yes. Switch off the tv main power supply off and on helps but then the problem will still come back.
I just want to kniw whether it is a common issue or my tv really got the problem. So far my tv also updated the latest firmware.
I noticed that if I don't diligently "exit" KODI whenever I'm done with it, the TV will become very laggy. Guess the TV is seriously lacking of CPU/RAM resources.
When this happens, I'll have to manually kill the KODI app (sometimes it hangs when exiting) or reboot the TV by pressing and holding on to the remote's power button.
Btw, have you applied the latest update that came out a few days ago?
Windowlover
Anybody know about trade in LCD, like to update to Sony TV for better picture quality...
nomoney25
How about if we get the australia/nz/europe remote WITH the record button? Will it work?
Not so sure but Sony has yet to activate hdd recording for the 2015 sony android tv thru firmware update.
I hope it work too!
btw. Can u check whether your tv remote will work and function properly after viewing on youtude video. Esp u keep on fast forward or rewind the clips.
Windowlover
I hope it work too!
Not only hardware I think in SG, license and media blah blah as SG control for such media show else MIO package and other movie packages will be cancel.
kun1he2
Talking about recording FTA channels which are broadcasted over DVB-T2.
Sony seems to be the only smart TV brand that doesn't allow HDD recording of these channels. Not sure if their non-Android TVs supported recording.
As for the REC button, I have mapped it to my Logitech Harmony remote.
The 65W850C Android OS doesn't respond to the button - but it does pass it on to other apps like KODI.
Not sure if other models will respond differently.
ralliart12
...Btw, have you applied the latest update that came out a few days ago?
Are you talking about a new update for Kodi? May I know how to retrieve it?
Just a resolution to my own query:
main problem: latest version of YouTube for iOS is incompatible with the 2nd-latest version of the GoogleCast Receiver app installed in the X85C:
source
Need to update the GoogleCast Receiver app on the X85C itself to restore casting capability. Be sure to check that your receiver app is at 1.5.something before update, & 1.6.something (or higher) after update.
kun1he2
Was referring to the recent Android TV update.
For KODI, mine was auto-updated to 15.2 - it should be automatic if you installed via the Google Play store.
Veron4
Hi why does sony tv 70x8500b unable to play live youtube steaming?
Does anyone know how to fix it?
Thanks in advance!
mrsun18
I can watch normal youtube streaming but unable to watch live broadcast of youtube,may I know how to fix it?
I see...To my knowledge, there is no difference between watching normal streaming and live broadcast as both are streaming data delivered to pc or tv or other devices.
Were you able to get into the live broadcast channel? The channel here has the same meaning as the normal non-live video seen in youtube.
If so, then perhaps the site has technical difficulty, live broadcast has not started, or live broadcast has ended.
You may want to try these 2 sites which streams live 24/7:
Sky News Live
url https://www.youtube.com/watch?v=y60wDzZt8yg
[On-Air] KBS World 24
url https://www.youtube.com/watch?v=QjRM_thMPec
Edit: Just tested using my Android phone, it says "live event playback is not supported on this client. Perhaps you can ask Sony Support for comments.
Veron4
Sky News Live
Thanks and I have just finished the call with Sony support and they said they sony tvs dun support the feature of live broadcast of youtube even in sony 2015 andriod tv. Kinda sad for sony users and potential ones.
mrsun18
Haha, earlier on when I clicked on the link from hp, the firefox browser launched and gave the message. I just tested again using the youtube apps separately and searched for "sky news live" and it worked! It left me wondering.
Veron4
What is ur model?
I did countless attempts but still fail to play live broadcast youtube.
mrsun18
What is ur model?
In case if there is any misunderstanding, I used my android handphone Lenovo A7000 to test. I don't have Sony TV :)
swathe
Does r350c and r550c have any screen quality difference?
