Sony Smartwatch 3
xphobic
S$298. scheduled for launch end of October.
298 sounds decent. Is it launch in SG?
Anyway just to check can the sw3 take calls like the smartband talk? I couldn't find any reference to it while searching online.
Any idea all?
adix_82
Any idea all?
Yes. Burlington Square selling it now. Can get from there as well
Rashkae
Bought mine from the Ngee Ann roadshow for 268. Loving it so far!
xphobic
Yes can reply thru voice. Whether they type correctly is another thing
Sent from GAGT Android App
carlover76
Where to buy this watch, my cousin call SONY store yesterday but no luck, SOLD OUT :(
I went to 313 yesterday and there is one set there, you can try Sony Centre at Sim Lim Square and I will be there later, can update you if you want. =:p
omelet
Just got this watch, awesome watch..:s12:
However, couldn't really change the bluetooth unlock distance?
Set it to a shorter distance but still able to change in a pretty far distance...:s22:
vche018
Hi may I know how to download songs from your mobile to the smartwatch. The only way I saw is using google play music under setting navigate to download setting tick the download to Android wear.Point is in Singapore it does not have this option to choose from the google play music.Anybody can advise alternate ways to sync the music from your mobile to watch. Thanks
omelet
Using Xperia phone? Use walkman app to sync.
Select playlist, choose walkman favourites and enable download to wearable.
