Sony Smartwatch
Chirashi
The SW2 has an extremely readable screen even under strong sunlight at the lowest brightness setting. Feeling curious, I decided to read up on its transreflective screen. Apparently it helps to reduce power consumption by using light reflecting off its pixels to improve readability, rather than relying on a backlight.
If someone comes up with a transreflective screen with colour reproduction and contrast similar to Apple's retina displays, we may see longer batt life of mobile phones in the future and less energy consumption for everyone. Amazing.
ahwheel
Hi all, I going to use my smartwatch 2 but before that I need screen protector for it. Anyone know where I can purchase??
carlover76
Jimmy will bring in the screen protector for Smartwatch 2 and stock will be in soon.
For me, I customize it at DataFlex for their Hi Resolution and Anti Finger Print at $15, if you want cheaper one then wait for Jimmy's stock.
qifatt
Hi guys. I just got the smartwatch2, can I use custom watch faces like samsung gear does?
carlover76
Just connect your watch to your phone and it will upgrade the firmware on your watch, there are some preset watch faces included in new firmware.
You can have new watch face by 3rd party developers but you have to pay for it and some might drain your watch battery.
qifatt
Thanks, I upgraded the firmware. Still not satisfied with the watch face :-(
Any nice and free watch face recommend?
carlover76
The Pro version for this Watch Face looks good but you have to pay for it.
https://play.google.com/store/apps/details?id=com.pixels.sm2pro
qifatt
Sad. samsung gear can change easily and even can design our own watch face....
carlover76
I see, that is because they come out an app to perform such functions but if you search in the playstore for apps for smartwatch 2, you can find many apps over samsung gear.
yhw22
Anyone uses the Runtastic Pro? Manage to register the code, but still Runtastic. No pro. Try using Walking, but distance still remain zero.
qifatt
Ok thanks a lot :) will slowly find go thru those apps
tekster
So apps made for sw2 cant be us3d for samsung gear? Shouldn't android be universaland across the board?
