Sore Throat
kakalicious
I know hot to get better
You don't have to take any medicine pills to get it better. Just drink tons of warm water, not hot water until the water tastes bitter. I am probably guessing 3~4Liter of water. You will get rid of that pain in two days!
twinbaby
I have been getting sore throat on and off every since. I got the yin chiao cough syrup from Cheers and it taste quite good.
xerref
Do you often have blocked nose or sinusitis? Post-nasal drip might be the reason. Also, breathing through your mouth might cause sore throat as it dries it out.
twinbaby
Salt water with gargle is the most effective solution I would say.
2nd try vitamin d3 regular it wasn't that bad as well
twinbaby
Got sore throat again
Day 1: Throat Pain mild
Day 2: Throat Very Painful , doctor give antihistamine and lozenges. Doctor advise it is due to post nasal drip. And suggest to drink water after using steroid spray to prevent bacteria to accumulate back of throat. Brought neuflo and difflam to reduce pain.
Day 3: Throat Pain Disappear, left side of nose produce a lot of yellow mucus, used a lot of nasal saline. Using nasal saline on right side is slightly painful. Like rub salt on wound
Day 4: Itchy throat, 👃 produces some amount of yellow mucus.
twinbaby
Day 5: Yellow mucus out of nose. Slight itchy throat. Took some vitamin C.
twinbaby
Day 6: Very bad cough, doctor prescribed acetylcysteiene, neuflo ,klerimed(antibiotics)
twinbaby
Day 7: Recovered. Still have some white mucus from my nose. But no more cough.
twinbaby
No white spot.
DAY 10 : Still got some white mucus out from my nose.
I just learnt one thing.
Going to the gym is breathing in recycled air. And there are a lot of bacteria around.
Is that one of the reason
twinbaby
Yesterday,
I have woke up with Woke up with slight throat pain, migraine and sinus.
What I did:
Drink a lot of water
Danzen tablet from pharmacy
Lozenges
Salt Gargle
Lots of Rest (Important)
delceer
Something is very wrong.
Where got people always got sore throat ?
You got go for full body medical check up ?
You always insert something into your mouth ?
Devilman37
Sore throat is a common illness
How is it possible to prevent it?
Gargle with salt water daily after you bush your teeth before sleep . Take manuka honey umf 15+ daily with a small teaspoon in the morning and / either once at night . Don’t not over do the honey .
Devilman37
By the way if the sore throat presist . Please inform doctor and go for a thorough checkup .
freewilly5000
Manuka honey will help as it’s a natural antiseptic. Don’t use metal spoon in honey as it affects the quality. If making honey tea use hot water not boiling water as boiling water also kills the goodness in the honey
twinbaby
Sometime when I wake up the throat slightly painful. Not sure if it is sign of sore throat
lizzykai
Hi. I’ve gotten peritonsillar abscess or quinsy. I’ve been trying to find someone to do incision and drainage for the stupid thing for a while. The Doctors I’ve seen just gave me antibiotics but my friends say only draining the pus out will help. Where can I go to do iad?
