Starhub Giga
Computeron
not bad... since CL no promo... at least got this free 10gb for existing. now 50gb le.
Kiwi8
Deluxe Member
The add on 10gb is useful for 6gb plan but useless for 40gb and above plan because you have to use up all your roll over data first then use up all your own 40gb data and add on 10gb data is use last. By the way this bonus 10gb data is not they 1st time give. Every month 11.11, 12.12, 1.1, 2.2 and etc they will give free 10gb data and sometimes they will give free 1-2gb data for Facebook and WhatsApp usage and also normal usage. I also did receive free 10gb last month on 10.10 and also some days last month I received 2 times free 1gb for use Facebook and WhatsApp and 1 time free 1gb for normal usage. If they got give free benefit is start from 12am from the day they start to give. You just need to go in the giga app once every day to check.
I didn't receive the free 10GB during 10.10 leh.
Kain999
Giga can i sign up today but choose the port in to be a later date near end of month or is automatic cannot choose one.
smileedee12
When you sign up, choose a new number. Port in at a later date.
This is where I want to ask the community. My current plan is with Starhub, ending on 16 Nov, which is a Monday. When do I begin the port over process in my giga app?
Kiwi8
Deluxe Member
16 Nov .
kopi22
10GB more.... Not bad....
Sent from Google PIXEL 3 XL using GAGT
lohsenglte
17 Nov and later.
If you port out on 16th, it means that your contract is STILL ongoing, and termination charge will be applicable.
(Line termination at StarHub end will happen at around 2200-2315 if approved, which is before the 0000 17 Nov, this is why it is considered breach of handset contract as well.)
Kiwi8
Deluxe Member
17 Nov and later.
Note that the question is 'begin the port over process in the app'. Giga is not gonna port over so fast. Need at least a working day, so a request sent in on 16 Nov is only gonna processed on 17 Nov earliest. So I stand by my answer of 16 Nov to submit the request.
gkyangcyrus
Hi,
is GIGA have multi sim for same number service, means you have 2 sim card same number which can be used in 2 different devices?
justln
Tried porting out but rejected by GIGA, anyone encounter this issue?
kazuki666
Sorry guys, i found out the answer with Giga Q&A liao. The $18 promotion doesnt allow to use referral code...
