Starhub Giga
MacSpicy Cheeze
Giga network in my room signal mostly 3 bar high 90s dBm sometimes 4 bars down 80s dbm
My giga signal kisiao one. Inside my room mostly 3 bars low 90s to high 90s dBm sometimes 4 full bars low 80s to high 80s dBm. If keep on 3 bars my battery drain very the fast.
Zzzzzz ok ok ok we get it....
Sent from HUAWEI YAL-L21 using GAGT
sporegirl
My giga! mostly only 2 bars and rarely 3 bars,
Cannot watch fb videos without lag.
That’s why I’m gonna switch to gomo and try.
Kiwi8
Deluxe Member
I ported out on Monday night 2/11, but was still charged on the 5th (my billing time is 5th of every month around 9pm). Do I have a case to get a refund?
If I'm not wrong, giga policy is one must notify them 3 days before billing cycle, to terminate at the end of the current cycle.
So if that applies to porting, then it probably also means u should port out 3 days before 5th of the month otherwise will be charged the next month subscription.
GrizzlyBear
what are the drawbacks on GIGA if there is? other than the VOLTE issue when calling?
Another from my short span experience was the accessibility to customer support.
They are contactable only through chat channels on the giga website/mobile app, Facebook messenger. Chat agents are only available during working hours and had to wait approximately close to 60 mins for a live agent to be assigned to chat with.
jayjay0702
When you say notify does it mean must write email to them? Because 3 days before the 5th is the 2nd which is the day I port out. The request was sent around 2.30pm, and received another sms saying the request is approved at 5.30pm. Not sure whether the 5.30pm affected the billing.
jayjay0702
+1 to this.
I waited 45 min to be connected 3 days ago
007Mi6
MyRepublic is the best $10 plan with low latency of the M1 network.
Nothing else come closer unless you want to be beta tester of the 5G network
p_eppermint
Which is better — GIGA or MR? I was previously on TPG trial plan and actually intended to continue with the $10 plan cos for 50gb its really cheap. But super pissed off cos they cancelled my plan even though I responded that I want to continue. And even though I immediately contacted them, they said can’t restore. Somemore it’s my work line, damn inconvenient :mad:
Just wondering if 6gb is enough though cos I play games on that phone too.
Jurong640
It's normal for giga to be like this. Inferior network to Singtel and it's mvnos. If you want faster speeds, chose grid or gomo.
Kiwi8
Deluxe Member
I think for porting, just make sure u initiate your number porting at the new telco early enough so that the porting takes place at least 3 days before your billing cycle.
GoodBetterBest
May be you check your previous charges to your credit card bill and see whether your port date is before or after that date.
In anycase, I don't think there is any cost to disputing the charge at the credit card centre (you can ask your credit card company when you dispute). So initiate a dispute first. They may reverse the charge also.
Good luck !
decibels
Number ported out from giga to vivifi, and yet the number is still inside my giga account.
justln
My Giga keep losing internet even at full 4G bars around Ang Mo Kio, Sembawang Canberra area, gonna swap back to GOMO at the end of the month.
jayjay0702
Good luck !
I finally got my reply back. Wrote to their gigacares email and said will refund me hooray.
Anyway, before contacting giga I tried disputing with the charge with DBS (card issuing bank). They said they don’t handle this kind of case and I should contact the merchant, and if all fails contact CASE? I’m not sure whether I’m doing something wrong or I’m supposed to contact visa/master? Hope someone can enlighten me
