Starhub Giga
TanyaBurr
Which plan is better?
1. 5GB plan for $10= 5GB of data, 100 minutes of talk time and 100 SMS
2. $25 for 25GB = 1,000 minutes of talk time and 1,000 SMS
Which plan do you think is more enticing??
Will StarHub coupon code and promotions be valid for these offers? Does anyone know about it? :s22::s22::s11:
vsvs24
Tomorrow have $18 for 20GB pop up plan. If it is still the same as Feb popup plan it will be $18 for 20GB data , 200 mins and 200 SMS.
Which plan is suitable depends on your usage for data and outgoing calls.
Hwsemb
Anyone also experienced failed SMS delivery when trying to send LONG SMS (i.e. 2 pages or more)? I suspect it is because the giga app cannot track and deduct correctly for long sms quota, so will restrict sending of long SMS?
UPDATE: I realized the giga app will proceed to deduct 1 sms quota even though the long SMS failed to be delivered.
BeefCutlet
Wonder if should sign up for pop up plan
Currently on 5GB plan which is enough cause I got TPG plan also...
But if continue on 5GB plan until TPG trial ends, got the risk that got no pop up plans after that
absolut777
Suspended
For less than $1/gb it is tempting.
However if 5gb is sufficient, and still get roll over data, I'd stick to it.
These pop ups come n go,so when notice usage goes up then switch lo.
Save the $8/mth for other necessity.
Note;my 2nd SIM also TPG but I'm clocking <5gb on both SIM per month.
vsvs24
If I am you I will stick to 5GB plan. I am on 5GB plan and TPG too (dual SIM phone). Since you are now on TPG, you should be able to roll over data. TPG is supposed to give 2 mths advance notice before they start billing. The rolled over data should give you another month. So in that 3 mths wait for pop up plan if you think you need more than 5GB. If short of a bit can pay $2 for 1GB.
tanchoo1
$18 for 20 GB pop-up plan now available on Giga via their app from 5 - 9 March 2020.
Pocoyoz
if Myrepublic network signal strength not good, change to giga signal strength will be the same?
Sent from Amazon using GAGT
Apex
Signal will be same. Speed will be diff as the backend route to diff apn.
