Starhub Giga
Richliao
i think for giga, you can "port-in later" to replace your current number. Means, you can subscribe giga with a new number, you can so-called try for a month, then apply for port-in to replace your new number with your current Orange telco number. Then you retain your old number.
I would suggest you try it out giga first with the $10 plan. I've tried giga before, not really impressed with it, and switched back to orange camp. But I switched to SIMBA afterward. Orange is pretty good in most places, but even with reception, data is slow. Giga is no reception or got reception, cannot receive calls.
I didn't know what you mean until I asked the mobileshop people. This is convenient, only giga can do this?
Uacesg
Hi all, using giga! and for overseas to receive otp sms, do I need to buy the auto roam package?
darksword995
Anyone here facing issues with receiving SMS with giga? Whether it be OTP or SMS in general. Checked the SMSC in my messaging app and nothing is wrong.
Kitaro9202
Dumb question if i go oversea, will giga provide auto roaming foc?
Can i receive, send sms, incoming and outgoing call?
stillgottheblues
Wonder if anybody here use pixel phone and get volte?
Don't get the phone if you want call over 4G. Pixel only uses 3G for calls.
And worse, Google and her support team don't give you a twist and turn answer that you cannot come into a conclusion.
You are better off with Apple, Samsung or some china phone.
Cookie Muncher
I think that's for new customers at partner shops only, and is limited to X months.
Details I'm not too sure, I didn't ask.
ahhh new sign up promo. no wonder i was searching on google only saw $10 for 10gb. :frown: even rollover to 20gb is kinda too little.
currently have 100gb which is too much :o
radon
Wah sian le scare receive call when oversea
No choice, gomo also the same if I remember correctly.
You have to consider those MVNO like zero1 then.
Bright side, you won't be disturb by call overseas & need to pay for it.
