Starhub Giga
chaiscool
Just signed up to $10 Giga plan this week. So far so good. Silly me didn't look out for promotions and ended up using referral promo code to get $2 off rather then the promo code to get $20 GB data
Also noticed the pop-up plan is not really a pop-up plan? It's available for existing subscribers to change to in the app. And this plan was also available for me to sign up through the app earlier this month even before the pop-up plan "dates"
Never sign up through shop? Get 30gb free for 12 months
Thanks, didn’t scroll earlier as I thought it was only 1 image uploaded.
Found the Shopee seller for anyone who’s interested. Shop branches listed in the description as well.
https://shopee.sg/Giga-Topup-10-i.36501223.18428028351
Soomp!
u are right. Giga do not support international SMS
Even if you wish to pay for it.
I need to urgently send out an sms to activate a banking token and it does not work !
Cyborg
How much data do you all use? Wondering whether should upgrade to 50gb pop up plan
How much data others used will be of no relation to your decision to upgrade.
Whether should you upgrade or not will entirely depends on your daily usage.
You can do a trace on your usage history with your current plan.
Also not forgetting that Giga has roll over data too assuming you are now with Giga.
Anyway, Giga's pop up plan for the 50GB ended yesterday.
TheBlackSpy
The pop up plan never ends. It's always available through the app
Cyborg
The pop up plan will ends to those who have never or not yet subscribed to Giga, but fret not, because it will pop up again weeks later.
As for myself, I was previously with Giga and then ported out to another telco.
However, I still retained Giga's app on my hp, hence the 50GB will always be available.
Cyborg
Thanks for your input.
Oh, what I meant is that whether the free 30GB offered by shop retailers can be rolled over.
I have asked one of those mobile shops, they mentioned if I subscribed through them, I will get an extra free 30GB.
Example if I opt for the 10GB plan I will eventually get 40GB in total, however roll over will still be based on the 10GB instead as claimed by the shop assistant.
Hence I am seeking for confirmation whether this is true, especially to those who have already subscribed through shop retailers and also received the free data.
In short, would like to know whether the roll over is based on 10GB only or 10+30GB?
xonix
https://giga.com.sg/TnC
4. Bonus data awarded as part of this Promotion cannot be rolled over to the next month. Usage of local data will start from Bonus data, Rollover data accumulated, followed by base plan data.
Cyborg
I read this too through your attachment.
So, store retailers free data given are considered as Bonus data.
I thought Bonus data was referred to those GigaGift, GigaSurprise offering free data, normally 2GB.
Thanks for your clarification.
a4973
Anyone knows if the 1.5 GB gigabuddy line can rx SMS while local in SG? Thanks.
unchecked
Just FYI even though in the T&Cs "fair use" is under the birthday promotion section, it also applies to normal everyday use.
I've been using it to live stream to youtube at 720p at 6Mbps, so after a few hours and I hit 10GB use, they will throttle my speed down to under 1Mbps.
When I emailed them about it this is their reply:
"The usage of your data is for your own personal use and is subject to giga's fair usage policy.
If we determine that you have exceeded our fair usage policy beyond a threshold at any time as determined by us in our absolute discretion, we may impose a speed limit on the applicable Service."
luckygal
Can I check for Giga roam, previously I was offered a promo at half price so I bought 1gb to keep. For how long can I keep the non activated 1gb before it expires?
froztheart
3.13.7 If your gigaRoam pass is not activated within 90 days from its date of purchase, it will be immediately and automatically forfeited from your account without notice. No refunds will be made to you in such an event.
kazuki666
Any Giga users tried roaming at JB and Melaka area? I may need to travel for work maybe next few months time. 1 - 4 days each. Btw, currently I am using the $18 Giga plan
radon
Better to get msia sim card then.
Cheaper and more worth it.
