- Aug 8, 2012
Checkout page, there's a field to input.Giga apac roaming 50% off. Where do you enter the promo code? Is it after clicking "let's roll"?
Don't have any minimum subscription. But do note sine U already paid your subscription fee, there will be no pro ratedI have just ported from starhub to giga. Feeling a bit unsecure that my phone is unreachable whilst overseas. Thinking to switch to simba or eight.
Could not find information of any minimum subscription period for giga. Anyone can advise?
Did you turn on 5G on your phone?Just ported in to Giga 5g $18 plan and opt for esim a few days ago but i dont have 5g connection.
Using samsung s22 ultra. Anyone experienced this before?
I ported into giga using s22u on physical sim a month ago. 5g no issues. Roaming data worked well in Malaysia. Only lacking roaming calls. Ported to eight for the roaming call capabilities. Same starhub back bone. So far so goodJust ported in to Giga 5g $18 plan and opt for esim a few days ago but i dont have 5g connection.
Yes. I checked and double checked my settings. Restarted my phone a few times. Since last fri till today no 5g.Did you turn on 5G on your phone?
Have you try to restart your phone ?
Have to reach out to them and checkYes. I checked and double checked my settings. Restarted my phone a few times. Since last fri till today no 5g.
Previously using myrepublic 5g from day 1 no problem one
Ported out a few days ago, no issue.Anyone having problem porting out from Giga?
I tried with zero1 in Dec and they said rejected by Giga as it is prepaid.
I tried again with changi mobile and it is also rejected by Giga.
I sent 2 tickets, 1 in mid Dec and 1 a few days ago and not a single reply.
Anyway else to escalate?
My first port out of another number is straight forward and no issue.
Try contacting them on FB, no issues porting out.Anyone having problem porting out from Giga?
Just try again, keep telling your receiving side telco to retry. I’ve ported into giga twice in the past few years, first try port out always fails.Anyone having problem porting out from Giga?
If you recieved this today, means your renewal was today or yesterday i guess?Anyone received this message from giga today?
Recieved this message as well on 2nd number which is on the same plan as yoursI'm on the $10 plan and it looks to be identical.
My renewal is today 18 Jan. I've never received this type of sms before, usually it's just a giga receipt email and sms.If you recieved this today, means your renewal was today or yesterday i guess?
But didn't recieve it on my main number which is on the 18 SGD plan
Mine was on the 15 and so far ya, first time getting this SMS as well.My renewal is today 18 Jan. I've never received this type of sms before, usually it's just a giga receipt email and sms.
Thanks for the info. In this case it does seem safe to assume that this sms is just a "new" format that giga may be adopting.Mine was on the 15 and so far ya, first time getting this SMS as well.
Never bothered with it since i login the portal to check and there wasn't any changes that i noticed.
I kinda panic for a moment when i saw the message, thought that i probably had done something and that was a best case scenario. But if you want, could just check with the CSO.Thanks for the info
Haha, i wouldn't mind but as a 2nd number, i guess its not a "need" to me in the meantime.give us more data on the $10 plan
Trueall other telco seems to be more generous with their data offering 100gb+ for the $10 range plan
