StarHub MaxInfinity Fiber Optic - Experience
Twilight
Oh i see.
I have tried out the Dlink 868L, wired connection able to attain around ~930mbs down/up
Wifi connection yet to test out the real AC speed as i currently do not own any AC devices haha.
But the range seems okay, can reach the same room previously reachable by my old ASUS router.
Then use the router.
Dont need waste money to get the Asus AC87.
radiancez567
500mbps plan.
Using D-Link 868L, on the 5GHz band.
On wireless, using Macbook Air 13 inch, 2014.
Not bad...
aqf
My local speedtest done awhile ago
tomb
having trouble accessing certain websites since yesterday.
luckyguitar
Blitzkrieg
is it only me or starhub torrent speeds are atrocious now? used to get at least 5mb/s. now cant even hit 500kbps
keigo
Twilight
I gett around 9MB/s for 1 Ghz fiber
is that good ?
downloading this http://torrent.unix-ag.uni-kl.de/torrents/KNOPPIX_V7.4.2DVD-2014-09-28-EN.torrent
what88
It's either they throttle or settings issue with torrent software, should be able to get near 25MB/s with 200mbps plan.
most likely is the setting, previously even worst. Recently after changed some setting, speed improved a lot.;)
Twilight
Using Synology NAS to download.. Max 9MB/s for BT.. Slowwwwwwwwww
Anyone know how to improve it?
oric1
kelvinti
< Good to get ? > SH Dual 500mbps Fibre + 100mbps Cable at $49.90?
Folks,
I'm planning to get the Starhub Dual Broadband 500 mbps + 100mbps Cable package at $49.90.
Reason 1:
To upgrade my current 100mbps Fibre to 500 mbps installed in my Living Hall for everyone in the family to use (Wifi connection usage only).
Reason 2:
I wanted a dedicated wired connection for my room's PC and Smart TV and Android TV box. So, I'm thinking that using the wired connection of the given dedicated 100mbps Cable router installed in my room would be much much better comparing of using the 500mbps Fibre Wifi connection.
So, at $49.90, technically and practically worthy? :s22:
Can try? :)
melvinchen
Folks,
Reason 1:
Reason 2:
Can try? :)
You might as well top up $10 per month and get dual boardband 1000
kelvinti
You might as well top up $10 per month and get dual broadband 1000
Hmm.....I'm not paying for the subscription!:o. My elder bro is.:D
Therefore, he is not willing to pay that extra $10 per month lor.:o
Anyway, no one uses the wired fiber connection. All are using wifi connection only.
Except myself that I need to use wired connection in my room only. Also, no cable point for fiber in my room. Also, can't lay long cable across the house due to human traffic!
The most important of all to me is that 100mbps Cable wired connection via the 2nd DL 868 AC router installed in my room for this package. :s13:
