Telcos support for VoNR
On the other hand, no need to worry about the lack of support for VoNR though for most of the users.
Your current 4G/5G phones will be out of security updates support before 4G LTE network is gone (say in year 2035 or a bit earlier).
6G network may start only in 2030, or earliest 2028 for small scale testing.
lenkiatleong
Do you know how to identify/ensure that a mobile support VoNR? Most mobile manufacturers will not advertise this support in their websites.
No idea here. I guess you have to go to the top Samsung Galaxy S24/S25/etc phones to be sure.
And even if the phone has the support of VoNR, the telco may not support, also no use. The situation is similar to VoWiFi but worse than VoWiFi as of now.
in my limited experience, the phone may support VoNR, but the telco may not support that phone, so effectively, from the user's POV, not supported
same situation with VoWiFI.
A7997A
I use my 4g everyday for phone calls. Seems fine to me. It's nothing comparable to the days where your 4g will drop to 3g during phone calls.
Yes, 5G SA fall back to 4G is much likely less disruptive than 4G fallback to 3G, but is still not ideal.
Currently I believe Starhub (& MVNO) + Singtel MNO plans are doing this anyway.
tuntun
Can starhub latest 5G unlimited + plan able to support this VoNR? does this plan is using NSA or SA?
BBCWatcher
As far as I can determine all Apple iPhones starting from the iPhone 13 models (including the 3rd generation iPhone SE) support VoNR from a hardware and operating system perspective, assuming you're not running an ancient iOS release. However, actual availability of VoNR is much more limited and depends on mobile carrier rollouts.
The iPhone 12 models are "interesting." Technically they probably could support VoNR. But evidently Qualcomm hasn't officially enabled VoNR for general use in their X55 modem (what iPhone 12 models have). SIMBA offers a voice mobile app that would provide a backup in the far distant future when they only operate 5G SA (and newer) network technologies, assuming their voice app continues to be available.
tkdboi
As of now, only for data. Voice still needs to use 4G (VoLTE) or WiFi (VoWiFi).
Very few Android phones support VoNR as of now.
my oppo find x9 pro started showing VoNR after I changed to a 5G+ Sim card today. on Singtel Sim Only plan
Eight 5G also show VoNR
5G SA, but haven't heard of any mention of VoNR.
Since Eight 5G can support VoNR, I believe StarHub 5G Unlimited+ and 5G Platinum plans can support VoNR.
But you probably need to use newer iPhones or some flagship Android phones.
tuntun
Any sign that showing on iphone 16 plus?
No symbols for VoNR for iphones.
But you can enable VoNR and test it by calling the number and check if 5G symbol is still there during the call or not.
Reference:
https://5g.co.uk/guides/voice-over-5g-standalone/
How do I get Voice over 5G Standalone?​
If you have an iPhone, then head to Settings > Mobile Service > Voice & Data, and enable the toggles for both ‘5G Standalone’ and ‘Voice over 5G Standalone’.
How can I tell if I have Voice over 5G Standalone?​
If you have Voice over 5G Standalone you should find a VoNR or similar toggle on your phone’s setting screen, but another way to test is to make or receive a call when you have a 5G Standalone connection, and see if the network signal on your device changes to something else, such as 4G.
