The Power Supply Chart
cnt
gtx295 req abt 320w on 12v rail only. even lower den 4870x2. hx520 has 480w n hx620 has 600w on 12v. hx520 is enuff n hx620 will gibe u more allowance :s42:
santaboi
sure can???? cus i going down later i dont wanan get the card and then come home cannot use
cnt
the cm430 got how many watt/amp on the 12v? :s42:
mkwh22
PSU advise
Hi, I am considering getting a new rig. Have done a little research and finally decided to purchase the following parts.
MSI K9N2 Diamond mobo
Phenom II x 4 940
Palit Geforce GTX 285 1 Gb (probably a 2nd one in the future for SLI)
2x DDR2 PC6400/800 2 GB ram
Seagate 7200rpm 320 GB HDD
Misc will include optical drives, keyboard and mouse etc.
I am wondering if a Thermatake Toughpower 850w power supply unit will be sufficient.
Thanks.
cnt
y not seasonic m12-2 430w? u use simi gfx? :s42:
cnt
can use seasonic m12-2 430w. modular n 80plus :s42:
HeeroYuy84
okie thanks for the advise, if vantec ion 2+ 500 watt ,verudium 600w which is better?
cnt
ya, verudium seems very light. used to be quite popular few yrs ago thou :s42:
cnt
how cum u dun choose seasonic? $10+ diff only :s42:
xonix
Andyson G530 sufficient upgrade for my 2yr++ Acbel p/2 450w?
Or Acbel E2 510w?
Use extreme PSU calculator, I will need around 347w at peak load for the following:
AMD x2 4200+
DDR2-1gb *3
160gb + 320gb sata hdds
GTS 250 512MB ( going to buy)
IDE dvd drives*2
creative audigy
