The Power Supply Chart
Andrew_Ng
guys is andyson PSU gd? or is corsair or OCZ better? cause i dun noe wads the diff
I would suggest Aerocool E85M 550w / Aerocool V12 600 / Andyson F650.
Review of the Aerocool V12 series. http://forums.hardwarezone.com.sg/showthread.php?t=2306959
All of the PSU that I recommend has 80+ Bronze which provides better efficiency hence help you to save electricity.
The PSU that I recommend is based on your budget per se.
If you just require 80+, can go for Aerocool Horsepower 500w.
xonix
Right now I am using only 1 of 2 molex to connect to the pcie connector via adaptor on gfx card, any issues? Gfx card able to run and gaming normally, no warning msg or shutdowns.
I don't have any spare molex on separate cable and from what I read online there is no point connecting 2 molex on the same cable. In fact it'll be more dangerous...overload
Should I upgrade to another psu with dedicated pcie connector?
cnt
if u r using 9600gt den no worry. reason to use 2 molex for pci-e is to distribute the current to 2 cables so tht it will not overload the cable :s42:
slim5143
Need advice on upgrading PSU
I have a Dell Precision T3400 with standard PSU (325W I think).
I tried to install an ASUS ENGTX295 (1792Mb) card, but there was no response. I assume there is not enough power from the existing PSU to run this card.
Does anyone have recommendations for suitable upgrade PSUs for this system ? My budget is around $300.
CPU is a Q6600 Quadcore, 8Gb memory, 2 internal SATA HDDs, 2 external SATA HDD, CD/DVD drive. Dual boots 32/64 bit Vista Ultimate.
cnt
corsair hx620 is more den enuff already :s42:
booest
this recent round up not bad.
some 400~500 psu review
xonix
What if i am using GTS 250 now? Just got the card yesterday.
Can bootup and played some games, no problem so far...however the psu almost 2 yrs old.
In tight spot as my PSU only have 2 spare molex and both on the same cable...
So far online search, the majority consensus is, best case senario plug each molex to individual cable should be fine.
But if 2 molex from same cable to the adapter is not advisable, may cause overload...
For now since I plug in only 1 molex no problem, will continue till i change to a newer PSU.
cnt
1 molex or 2 molex only diff is the cable load/temp. i nv heard b4 2 molex from same cable to the adapter will overload. usually the gfx card will draw only the power it need. if u use gts250 den i suggest u touch the cable after gaming see hot or not. otherwise ur cable cao tar :s42:
slim5143
I just noticed that the NVIDIA website recommends minimum system power of 680W.
Would the Corsair TX750 be a better choice than the HX620 ?
cnt
dun need. the hx620 has 600w on 12v. more den enuff for u already :s42:
Mystyque
Try to reconfigure your cabling to see if you can shift something to this cable so you can split the load for the graphics card.
Alternatively, getting a molex splitter is a cheaper option to add a connector to one of the fully used cables. Although the power draw of the GTS250 isn't likely to cause a problem.
If connecting both molex of the PCIe adapter to the same cable will cause an overload, then plugging in one will do the same thing.
xonix
Currently my cabling is as follows:
CABLE A ( 2 molex ) --> 2 dvd optical drive
CABLE B ( 2 molex ) --> 2 sata hdd
CABLE C ( 2 molex ) --> 1 for gfx card / 1 for 80mm fans
I can try to split the CABLE A but its quite a reach to the gfx card but until then it shall have to make do till my next psu upgrade. :o
yeah my thoughts exactly...let's say it won't cause overload but since plug 1 or 2 also from same cable so no diff since the power is still the same
cnt
the gts250 not using 2x pci-e power connectors meh? :s42:
xonix
Depends which brand you buy loh... some are 2 and some are 1
The supposedly reference nvidia design for GTS250 is 1 connector only but they don't restrict the vendors from using custom pcbs
cnt
if 1 connector lagi worst. maybe it will draw >8 amps at full load :s42:
kanewashere
Hi what power supply would u guys recommend for an
Intel i7 920
p6t deluxe v2 mobo
and LeadTek GTX260 896mb DDR3
Any help would be most appreciated.
Or should i get something cheap like Spire Jewel 650w psu
cause i don't really know the difference... =(
Any help would be appreciated thank you!
