The Power Supply Chart
lyfeforce
Senior Moderator
Senior Moderator
ER said:
The Odin 800W GT is out? Thanks will update the chart soon.
I hope it's 800W, if not paiseh. :o
But I definitely saw Odin GT.
ER
Hmm I will check it out to confirm, thanks for informing anyway.
saviourz
hey everyone..
i'm experiencing a bit of a overheating issue with my psu
i've notice that whenever i'm plaing graphic intensive games or stuff.. i realize my com is ultra hot..
when i say hot i mean very hot.. hotter then usual.. around like 45-50 degrees.
it's my PSU.. when i touch the casing.. it's the psu that are emitting the heat..
anyway i'm intending to change a PSU, maybe to a R8 607W psu
any advise guys ? the cheapest and best ?
my rig is there --->
jtchoy
Your 440W might be running at close to full load, which is causing it to run hot.
Changing to a higher wattage PSU should solve the problem.
ER
Ok I have just confirm the Gigabyte Odin GT Series currently only have 550W, the rest of the models should be coming in by next year.
lyfeforce
Senior Moderator
Senior Moderator
Oh dear, my bad. :o
epos
saviourz said:
hey everyone..
try what i did:
remove the PSU from the casing, run the wires thru casing opening for PSU to the motherboard and other devices. now check if your PSU is hot, if the PSU fan has rpm monitoring lead to motherboard, even better.
my old enermax 431W will run its 80mm at full speed when system is under full load. but a check with energy monitor show the system only draw ~120W from wall socket, way lower than the PSU rated power. when i remove the PSU from casing and run it, the fan never go over 2000rpm. so in my case, it wasn't struggling PSU but a system too hot for the PSU--hot air drawn into the PSU, the fan have to work extra hard to exhaust them so as to not overheat the PSU component.
jtchoy
epos said:
try what i did:
For this kind of case, a bottom-mounted PSU will definately help, fresh, cool air entering the PSU instead of hot air... :)
epos
preciously. :s7:
saviourz
ohhhh.. but for my case.. my component are all hungry for power..
the case removal thing sounds complicating..
remove PSU casing.. never tried it before..
hahahs
anyway the reason for changing PSU is to have some extra room for overclocking
and i know my PSU is running close to full load.
anyway thanks for all the infor guys..
anyway how u know guys know how much wattage ur psu drawn from the power socket ?
ER
New psu added for modular chart.
There is some promotion going on for enhance psu right now.
ENP-5146GH 460W - $89
ENP-5150GH 500W - $109
ENS-0555 550W - $129
ENS-0565 650W - $155
Available at videopro and potterhouse.
Weekend promotion for verudium & seasonic psu from 28/11 to 02/12.
$20 off Verudium Vortex HE psu
$30 off all Seasonic psu
Available only at Bell.
saviourz
what are those PSU ? are they good, 80 plus certified and SLI ready ?
ER
Yes most of them are, you can refer them from my chart.
jtchoy
hahahs
He didn't mean remove the PSU casing, that is dangerous and voids your warranty. He meant remove the whole PSU from your comp's casing (which holds the motherboard, hdd, optical drive, etc...).
