Thinning Hair problem
mochi8
Does the NSC do any blood test to see if you are deficient on any vitamins first before prescribing the usual minodoxil? For a female...
MrLampa
Hi anyone bought irestore pro and does it work? Anyone taking biotin pills? Currently I am using the OGX Biotin Shampoo. Not sure if it works as well.
TheOMan
Anyone knows where to get Dutasteride (Avodart) locally?
I'm pretty sure it has to be prescribed by a specialist - probably a urologist - as it is primarily used to treat benign prostate hyperplasia (BPH) with the 'side benefit' of treating hair loss. I was on it for 2 years to treat BPH. It's pretty strong stuff although I didn't experience any serious side effects - apart from the loss of chest hair of all things!
foo9883
I'm 29 and experiencing thinning hair and balding.
Super scared now.
What form of treatment can I use?
Is there any doctor I can go to and if yes, where?
Sorry for not reading the entire thread to find out the answer cos u know, this thread is 400+ pages long..
Gabriel_23
Super scared now.
Finesteride
Sent from Xiaomi REDMI NOTE 9S using GAGT
revenant
Dont mind can share which doc? Also, is it really the same effectiveness? Have been using minoxidil for 2 years with no effect... worried that finasteride may not work for me too
Indian doctor. Can't remember the name. I don't think I'll ever take finasteride. Sex drive more important than hair loss to me lol
SibehEng
Is nsc the only place to get fin 5mg? The appt will take a long wait. Does those general clinic sell those 5mg type where can cut into 4 pcs? Propecia is too exp.
Sent from Huat Huat Huat using GAGT
Ragemage
Oh, i am actually curious how does it stack up against Finasteride in terms of slowing hairloss. There was a youtube video where Ashton Kutcher talked about being on it to treat his hairloss.
TheOMan
From what I can recall, it’s basically a more potent version of Finasteride. The potential for side effects will be higher too.
krazynoobie
Super scared now.
there is only 2 FDA approved treatment so far. One is to use Rogaine Foam. Can get from Ebay local sellers. another is to take finasteride. need doctor prescription. have side effects.
use Revita anti dht shampoo. get from lazada. use all 3 for best result. any other methods such as wad laser comb, beijing 101 all are nonsense and dont work
freebies4lyfe
I used to struggle with hair balding too.. Medication didn't help so i resorted to hair fillers instead. I did mine at prettyfun beauty place, can consider if you've yet to find a good doctor.
foo9883
I noticed minoxidil there's foam and non-foam ones.
Foam ones better?
voxvoxz
Proscar Finasteride MSD (Made in USA) 5mg WTS
I have left 1 brand new box of Proscar Finasteride MSD (Made in USA) 5mg of 30 tablets
Expiry Sept 2021
Pls msg or email me at voxz77 at yahoo.com.sg if interested
mochi8
Can I check if go poly, will they assist to do any blood test checks like thyroid, blood count etc for you? Or just directly refer to NSC without doing anythg? Many thanks.
EdenHazard
Foam is easier to apply (will not drip down so easily from your crown to your face neck etc) and dries faster. but some scalps are sensitive to the foam. Personally i prefer liquid form as it seems to work better for me (less hairfall observed). Downside is it takes longer to dry and you got to wait for it to dry before can style hair for work/school. Try both and make your own conclusion
Bostism
For hair loss, the doctors usually will eye-ball your head quickly to make sure it's not something urgent. Because if it was Alopecia Areata, that is an auto-immune condition and urgent intervention.
If you are just wanting meds, then you are out of luck, because polyclinic now stop selling finasteride and minoxidil. They will refer you to NSC without doing much, but then the wait time to public hospital is long.
If you are wanting something more holistic and not just medications, the polyclinic doctor can do simple blood test before making any further decisions.
