SecretAgent
- Mar 15, 2002
Do they have any app to monitor data usage?
Too many respondents so they closed it again.
Anyone know how to connect wireless@sgx with TPG sim.
I want to know also
free data you still wanna connect to wifi?
android phones try to connect using the same method via sim, and iOS use the app lor. if can connect means can, cannot means cannot.
It seems like cannot enable personal hotspot on TPG. Anyone tried and can work?
Can, I use it when I do spring clean and switch off the fibre bb. it is quite fast, so no need mifi, just an old 4g phone.
Ya, finally know how to do it. Need to set TPG in hotspot APN
Missed the boat. Can still sign up?
Am using TP-Link M7310 which supports 4G/LTE. I have tried both 2.4 and 5ghz no difference. I did the test with the mobile router just next to the ipad4 so it wouldn't have any impact.
Oh that probably explains what I had experienced. Cos when I use Speedtest to test on ipad, shows fast speed but when using the apps to download drama super slow and I could not figure out why. Since they are probably doing this traffic shaping/throttle thing... then I suppose even using a 4G usb dongle plugged into a router would be affected. Heng never buy the dongle, was thinking whether to get it so can broadcast through proper home router.
But if I hotspot from iphone instead of from MiFi, speed wise seems ok though.
