TPG Technical Discussion Thread
CPTMiller
If want apply another new line. So need to upload all documents again? The account portal does not seem to allow add new line
hereiam7788
Under the plan review tab on portal which is beside the real-time usage tab.
I see. I believe ur plan is still on trial rite despite the message l.
And I believe you did not select the option to renew the plan to $10 rite?
Instead, you have selected the option to terminate upon expiry on 30 May or you did not even make any selections at all.
myjunkid11
No. 2 SIMS I opted for the plan and there I see this msg.
The other one which I have decided to forgo is still showing the msg if sign up or terminate.
All the 3 still under 2GB/day.
Sidler
I login to check. Under "Services", it says the plan was activated on 11/06/2020.
So they collected money from those who opt in, but didn't cancel those that didn't do anything.
It's cool though, I got 2 more cards still free.
Broadwalk
i see i see. so ur plan billing cycle starts today?
did u use back the old TPG sim card for the new plan? i dun think there is a need to change sim card while switching to the new plan rite?
I think the bill cycle should be 15th of every month since my plan begins on 15th Jun. :o
There is no need for me do anything, the service continues as usual. :o I am using the old TPG sim. :o I keep the number since it is a nice number. :o
CPTMiller
Noted on multiple accounts/SIM per NRIC. But does the login ID needs to be unique or can 1 login ID got multiple SIM?
Sent from Samsung SM-G973F using GAGT
I suppose you need 4 email address to cater 4 TPG lines??
Broadwalk
Yes but E5773 has many version but 609 fits the FDD and TDD bands for TPG
4G BAND: LTE FDD B1 (2100MHz) / B3 (1800MHz) / B5 (850MHz) / B8 (900MHz) / B26 (850MHz) , TDD B40 (2300MHz)
Thanks but how we determine if it is lock or unlock unit? :o Anyway I have no idea what is lock and unlock unit. :o
fattyboi
Any idea which countries do TPG covers for the 1GB data roaming?
I tried to search for the information on their website but cannot find any.
Thanks.
