TV tuner recommendation
koohansen
I wonder is there any Digital Tuner cards which is certified to receive 1080i res :o
and any capture card which is able to capture 1080i/p res via component input :s22:
FattyTW
but i wonder got wat good tv tuner with hw encoding n price must be cheap or so called reasonable. looking for 1, interested to record tv shows, haha
boontiong
Digital or Analogue?
got wat difference? My motherboard PCI slot hard to put in due to my poor cable mangament and got one more slot in motherboard think is PCI Ex1. If usb will it be mafan?
Budget less than $100 to $110.
Looking for one as my old card seem like got problem.
innocent_boy
Digital means can receive digital channels
Analogue means can receive analogue channels
hkingx
can laptop use tv tuner? how to find out if my laptop have tv tuner?
rollbread
Wad's the diff between analogue n digital? Onli digital can receive HD5 is it? USB and PCI tuner got wad diff? USB can adjust the location to recieve better is it?
LxIxVxE
Senior Mentor
think i go for analgoue one.
simple one can juz get the leadtek PVR2000 @ $59 lor!
get the correct model hor, PVR2000 with hardware mpeg2 encoder, not those TV2000XP series~!
if next time needs digital or HD5, can always add in a digital tuner~!
then can watch/record 2 channels while a hybrid one can only play with 1 channel at a time~!
