TV tuner recommendation
LxIxVxE
Senior Mentor
fatty shushu from last yr talk till now still haven't buy~!
no action talk only~!
sunsetbay
Moderator
Moderator
My HVR1300 is a very old card. :o
Its an OK card, but due to aspect ratio issues, I always have two vertical black bars appearing at either sides of the screen (I am using a 24 inch widescreen monitor). Any idea how to remdedy it?
Thanks!
totalmedia can force the image to 16:9. :s22:
ducky_88
any analog tv tuner card tat support window XP and is recordable for a 15 inch lcd monitor:s11:
aabeesee
using my hvr1300. issit possible to use wintv for hd5? have to switch between both totalmedia and wintv veh mafan. prefer wintv :o
DLLMCH
Do you have AverMedia brand USB tuner in SG?
This brand is good, they use their own software (not unstable TotalMedia), which is very stable and low resource consumption. On systems that marginally meet requirements, it performs very well. AverMedia is made in Taiwan not made in China.
www.avermedia.com
ducky_88
www.avermedia.com
nice graphic.. wat is the model of ur tv card and how much does it cost? digital or analog? :s13:
DLLMCH
Singapore, I think, is the first country in Asia started Digital TV broadcasting, but Digital TV is still not that popular. Other countries started late but get popular much faster.
ducky_88
any software that can record chnls & clear?
PS: dosen't take up alot of space while recording.
silverstone
sorry to hijack this thread guys, any tv tuner card to recommend for da below requirments:
:using USB
:support for windows vista
:input signal is using coaxial cable (not using attenna)
HuMaNx
im oso looking to get a new tv tuner. But i have 1 burning ques... will my aerocool Horsepower 500w be able to support----> my rig is as display at the side
shunjie84
yea i'm looking for a usb tuner.. any recommendations?
for now DMB850 Plus (DVB-T and DMB-TH) is good issit?
shunjie84
any reviews on this leadtek tv tuner?
looks cheap and gd but dunno the actual quality how...
