jeffprobst
- Nov 25, 2001
im also using this, but plug is SG/UK plug
how much did you pay for your 65w GAN travel adapter?I rather buy 100w GAN travel adapter
i have 65w GAN travel adapter, charge my phone very fast also..
Around $30how much did you pay for your 65w GAN travel adapter?
realised that gan travel adapter charger very ex
100w better for 2 parallel phone charging horAround $30
100w i think ard ~$45
better than fixed uk plug..
i use this 1
yup, thats why have to check the detailed specs for the exact usethe port so many but end up only 200w?
Good price
Yes. Pls avoid TB PDD for all these devices. Some morons can still recommend Pdd. Gosh.Now for power related charging etc I dun dare to get those OEM brands cheaper options liao, ever since got fire incident that need scdf to come, I now really don't mind spending abit more $20-30 to get a more reliable brand charger with proper safety protection built-in. To protect my family and also to device, don't scrimp on chargers liao.
Like what others have shared I think ugreen anker won't go wrong, avoid those bo brand or cheap but super high wattage ones
65w enough alrdy for me.100w better for 2 parallel phone charging hor
bro why you chose this and not u-green? how you get $32?
The watts drop very fast..after 20%, worse after 80%
It will auto distribute
I don't think so.oh so 65w you mean is good enough for
1) 2 hp
2) 1 lappy
since after 20% it will be slower hence don't need so much wattage and at 80% it's even slower?
no prob if u can waitoh so 65w you mean is good enough for
1) 2 hp
2) 1 lappy
Sry what I mean if either 2hp or 1 lappy but not both at the same time. I guess is ok then . TksI don't think so.
From what I measure with my wattage meter during charging:
1. Normal non gaming laptop will use around 30-40watt constantly after full battery
2. Hp is usually will take 18-24watt most of the charging time. android or apple phone around this wattage.
So 65watt is good enough for 2hp OR 1 laptop. You may want to avoid maximizing the charging wattage all the time, it will shorten the life of your charger due to heat.
The problem with this PD charger is their chip will have fixed distribution wattage chart, they are unable to always maximize it at 65w/100w. See the previous post above by Devilsire.
Eg: for 4 ports 100w with all port in use.
USB-C1 45W+ USB-C2 30W+ USB-C3 7.5W +USB-A 7.5W. You can sum up the total is 90w. The charger won't be able to regulate just nice 100w for you.
What you mean by fixed uk plug? You mean they provide adaptors?Around $30
