UniFi Setup | Dream Machine
uncle_josh
Why are you switching it off every night? You barely save anything on your utility bill.
it is a good to turn off your modem and routers at night when not using. Personally I would encourage it.
Sent from 天作孽 犹可恕 自作孽 不可活 using GAGT
Vulpix
Moderator
Moderator
Why is it good to turn off at night when not using? :s11:
giraffey
If I have usg do I still need cloud key to host the controller? Thanks
The controller can also be installed on a computer. It also does not need the controller to be running 24x7 to make USG work. But, having the controller up and running will enable statistics/logs, auto backups and updates, and other AI/automated functions to be performed. I use a cloud key as running a computer 24x7 is heavy (in electricity). But, if you have a 24x7 machine in your environment, you can use that machine instead.
giraffey
Dunno telnet n Already fixed on ceiling and May haf difficulty bring it down 2 reset... was hoping for A network scan to discover it and adopt back. Find ubiquiti kind of hassle to use. My network r switch off every nite so next day nanohd was shown as disconnected in controller so I tot I can forget it and add back easily but didn’t expect this hassle. Sighz
If you mounted it as intended, you can actually to rotate the AP to remove it (you might need to lift the lock to release). Once detached, the reset button would be accessible.
moron+genius
The controller is currently installed on a laptop that’s not 24/7 and had scheduled the WiFi to switch off in the nite, so w/o the laptop running 24/7 the WiFi schedule will not b implemented?
giraffey
Not sure about the wifi schedule function though. Perhaps, you can test it out?
BradenHeat
sorry for the late response,
not sure if it helps https://www.youtube.com/watch?v=lH6_iET4Zbs&feature=youtu.be
but as the rest has pointed out,
its meant for the AP to be centrally managed via another Switch, aka the UDM pro or similar.
https://network.unifi.ui.com/#/controllers/1/50
as for the remote control, you will have to use the unifi cloud Reference reddit link
https://www.reddit.com/r/Ubiquiti/comments/b0u2jz/remote_access_unifi_controller_public_ip/
however, for some reason they have disabled, or removed it. Used to be able to remote login with 2fa via any normal web browser .
problem now is, its gonna be alot long winded to access via telnet if you’re not familiar
Repsol_2
common sense, bro
Common sense tells me not to turn off. it's 24/7 equipment. :s13:
You are the first person ever i heard shutting network at night. hahahaha
mrkiasu
In a nutshell and layman:
You need the cloud key if you wish to have hybrid cloud control for your network.
The cloud key works like a man in the middle between your home network and the internet.
With the cloud key, you can access your home network from anywhere in the world as the cloud key is "hosted" by Ubiquiti cloud server (AWS). [free for up to 10 cloud key per Ubiquiti account]
For more in-depth users, some may opt to use their computers/servers as their controller and enable cloud access to do the "cloud key" job, may not be workable for some and home users.
It all depends on each's appetite.
Ubiquiti has solutions for "almost" all possible scenario, depending on the System installer skill.
Walk around outside almost any MRT stations and those LTA camera's monitoring illegal parking on the roadside are almost all using Ubiquiti wireless bridging.
-UCT
mrkiasu
Yes, it will still work, as the config has been "pushed" to the AP.
Ubiquiti AP's are fat AP as in the AP gets the config and not that it has to be 100% dependent on the controller.
Controller "only" has to be 24/7 if you are using the captive portal or DPI.
-UCT
mrkiasu
To each their own. Cant be "forcing" people to no switch off their networking devices.
My home Wi-Fi was used to set to off from 1am to 6am till WFH and overseas con-calls coming in during the odd hours.
Unifi are meant to be on 24/7 without issues.
BradenHeat
-UCT
Eh... ? seriously ..? didn't noticed sia....
those are the long distance AP to AP bridged right ? :s11:
BradenHeat
Just wifi bridging but using TDMA.
SG not that long distance lah. Mostly below 500 meters.
everything is long distance to me if i cant stream netflix HD smooth and youtube 4k fast enough:o:o=:p /jk
i assumed, from field folks who are in the networking line, that Aruba would be the go to choice if possible ? :s11:
miloaisdino
aruba is good but expensive
