Vacuum Robot With Mop
fade_white
Using roborock qrevo max, not bad but can’t beat manual mopping. Nowadays got pro model maybe better
Foetid
U so eng to mop everyday?
Just put some no rinse detergent, spray spray spray. Then wipe. I normally wet the cloth first.
The roman mop also good, can sweep and mop at the same time. But alot of friction, easy to pull than push. Can use to scrub Somemore.
how much the spray mob?
articland05
roomba is the king many yrs back but now the throne is taken over by roborock/xiaomi
szeli
using Airbot brand. autoclean. just need to change water/add detergent..
p00p00
roborock qrevo doesnt work for me esp with pet hair. Wet vacuum ftw
szeli
they were probably sitting on their first mover advantage and continued to sell 1k+ roombas with just anyhow fuzzy logic. once the room mapping robots came out they were left in the dust
wongminmin
see your pocket how deep loh. best 1 is roborock.
cheap 1 is xiaomi
top sale is airbot
galant22
used to use Roidme Eve Plus, quite cmi. lasted about 18mths then the software uplorry. cannot control or map ki siao
now using xiaomi x20+, cant be any happier with the purchase. bought for about 450ish too
