Vacuum Robot With Mop
harky
Can buy a ramp for the kerb. Newer roborock model also can climb kerb
i got try before but the ramp take up too much space.. if i put ramp , i cant open my fridge door.
my kerb got 8cm tall
randyap
me just bought roborock qrevo 2 flow during ndp promotion. so far used it a few times only, floor cleaner than my wife mop. just that the 90 degree corners need once in a while use a wet tissue and wipe over.
testerjp
What type of house got 8cm tall kerb, your robot needs to mop your bomb shelter and toilet too? Abit not easy to be your robot leh. :(
uponly
I use D20 but no water on robot so keep expectations low. Can set it to go back station to wash and to saturate the mop again every 5m2 of cleaning. High end models got water on robot so it won't mop 'dry'.
SeeClothes
This one not bad...
https://www.tau-robotics.com/
ksapple
You so daring. I also looking to find alternatives as their house brand detergent so expensive. But also scare if anything goes wrong, warranty voided.
warranty also 1 year only i think.
I tink as long as its viscosity is same as water there should be no issue.
1 problem i notice is the container become opaque lol.
ksapple
ANyone using pipe in de?
i like to know if it is better?
I am think of getting Saros 20 R&D
Kwein
astopip
That's really tall! My parents flat built 1980+ the kerb less than 5cm only.
mingj
Rather then getting a vacuum robot with mop..
Get a vacuum robot and a mop robot.. Easier to maintain and not easily spoilt.
Nakedtoes
Give u a tip.. Push 2 droplet of dish detergent. No issur
