Vacuum Robot With Mop
Dr.Vijay
Administrator
Administrator
andriod
Is it optimal to mop and vacuum at the same time? Because when the floor is wet from the mop, it will be difficult for the vacuum to sack up the dust from wet floor.
harky
u r right... hmmmm think is vaccum thn mop ba
harky
Now i looking for slight cheap mop for Kitchen only :D best it can avoid the floor mat
rEe_TaN
U so eng to mop everyday?
Just put some no rinse detergent, spray spray spray. Then wipe. I normally wet the cloth first.
The roman mop also good, can sweep and mop at the same time. But alot of friction, easy to pull than push. Can use to scrub Somemore.
I used tienco wired version S5 series.. mop, vacuum and steam at the same time! Good! Though it's heavy but it save me a lot of time!
jumpthepig
AnTzX_
i using roborock for few years liao i feel not bad.. :o
nit3ex
Mop without detergent is as good as not mopping. And most vacuum robot with mop doesn't allow detergent to be poured into the water tank.
ksapple
i pour dettol for the past 2 years no issue
hachi
Need to buy those with cheap replacement parts. Using roborock Qrevo S
harky
they got sell own brand detergent what
