ViewQwest Fiber Broadband Official Thread - Part 3
andr3wyong
does vq need to update on their end whenever i change port forwarding rules on the zhone?
Don't need. You might want to check your PC settings itself as well, eg has your PC IP address changed since when NOC helped you create the port forward.
HexenHeretic
i've checked, doesn't seem like i overlooked anything else
i've set the ip address of the PC to static, updated zhone to port forward to that static ip address
edwin21
However I managed to traceroute ds.test-ipv6.com so I'm not sure where it's dying.
probably this is the reason why - unreachable prohibited 2001:470:1:18::119 @ 2001:7fa:0:1::ca28:a101 [rs1.hkix.net]
Code:
00:36:03.490147 IP6 (hlim 126, next-header TCP (6) payload length: 32) 2001:d98:xxxxxx.53237 > 2001:470:1:18::119.80: Flags [S], cksum 0xc05f (correct), seq 2437179659, win 8192, options [mss 1440,nop,wscale 8,nop,nop,sackOK], length 0
00:36:03.526869 IP6 (hlim 59, next-header ICMPv6 (58) payload length: 80) 2001:7fa:0:1::ca28:a101 > 2001:d98:xxxxxx: [icmp6 sum ok] ICMP6, destination unreachable, length 80,  unreachable prohibited 2001:470:1:18::119
00:36:03.690145 IP6 (hlim 126, next-header TCP (6) payload length: 32) 2001:d98:xxxxxx.53247 > 2001:470:1:18::119.80: Flags [S], cksum 0xbd89 (correct), seq 3922596685, win 8192, options [mss 1440,nop,wscale 8,nop,nop,sackOK], length 0
00:36:03.694170 IP6 (hlim 126, next-header TCP (6) payload length: 32) 2001:d98:xxxxxx.53249 > 2001:470:1:18::119.80: Flags [S], cksum 0x68d1 (correct), seq 2583672786, win 8192, options [mss 1440,nop,wscale 8,nop,nop,sackOK], length 0
00:36:03.694264 IP6 (hlim 126, next-header TCP (6) payload length: 32) 2001:d98:xxxxxx.53248 > 2001:470:1:18::119.80: Flags [S], cksum 0x1bee (correct), seq 2782918870, win 8192, options [mss 1440,nop,wscale 8,nop,nop,sackOK], length 0
00:36:03.725375 IP6 (hlim 59, next-header ICMPv6 (58) payload length: 80) 2001:7fa:0:1::ca28:a101 > 2001:d98:xxxxxx: [icmp6 sum ok] ICMP6, destination unreachable, length 80,  unreachable prohibited 2001:470:1:18::119
00:36:03.729341 IP6 (hlim 59, next-header ICMPv6 (58) payload length: 80) 2001:7fa:0:1::ca28:a101 > 2001:d98:xxxxxx: [icmp6 sum ok] ICMP6, destination unreachable, length 80,  unreachable prohibited 2001:470:1:18::119
00:36:03.729506 IP6 (hlim 59, next-header ICMPv6 (58) payload length: 80) 2001:7fa:0:1::ca28:a101 > 2001:d98:xxxxxx: [icmp6 sum ok] ICMP6, destination unreachable, length 80,  unreachable prohibited 2001:470:1:18::119
also VQ dns can't resolve the hostname ds.v6ns.test-ipv6.com required for the testing
Code:
>nslookup ds.v6ns.test-ipv6.com 202.73.51.98
Server:  ns1v1.vqbn.com
Address:  202.73.51.98
*** ns1v1.vqbn.com can't find ds.v6ns.test-ipv6.com: Server failed
>nslookup ds.v6ns.test-ipv6.com 132.147.113.3
Server:  ns1-res.vqbn.com
Address:  132.147.113.3
*** ns1-res.vqbn.com can't find ds.v6ns.test-ipv6.com: Server failed
>nslookup ds.v6ns.test-ipv6.com 8.8.8.8
Server:  google-public-dns-a.google.com
Address:  8.8.8.8
Non-authoritative answer:
Addresses:  2001:470:1:18::119
          216.218.228.119
>nslookup ds.v6ns.test-ipv6.com 2001:0d98:0e00:0002::3
Server:  UnKnown
Address:  2001:d98:e00:2::3
*** UnKnown can't find ds.v6ns.test-ipv6.com: Server failed
>nslookup ds.v6ns.test-ipv6.com 2001:4860:4860::8888
Address:  2001:4860:4860::8888
          216.218.228.119
epigram
I have the same problem. Thought it was my ipv6 configuration. However ipv6-test.com works and some of the mirrors for test-ipv6.com work too
basbot
Issue with customer support
I have been a ViewQwest customer for quite a while now, and today I called up the tech support because I was getting a very slow connection last night, and this morning, I can't connect at all. So before I left for work, I checked the unit, cables, and restarted the unit a few times.
I then called up tech support, and reported my issue, and according to them, they are unable to detect my unit. However, they will not dispatch a tech to my house until they have done some basic troubleshooting. I told him I am not at home, but he said he can't send a tech unless I complete the troubleshooting. So I asked him what are the steps in the troubleshooting. He mentioned if the cables are ok. I said yes, I checked them this morning, and I could connect to the unit itself, so the cables must be good. He then stopped and said there is no way I can verify that if I am not at home. To make the story short, he refused to troubleshoot anymore, and told me there is nothing that can be done. When I asked to speak to the manager, he said I need to wait for a call back, usually between 24 - 48 hours.
I cannot imagine this is the level of support I am getting from ViewQwest, and that they expect us to be happy with a callback after 24 - 48 hours, and that I am to be without internet access for a few more days after. I thought we are paying for a premium service here, but the support I am receiving are below standard. I hope someone from ViewQwest will be able to look into this, and correct it from within.
andr3wyong
Physical troubleshooting with the fiber patch cord has to be done as well. The staff could certainly have explained it better.
Do PM me the case number and I'll remind the staff involved to be more cooperative.
But please take note that physical troubleshooting of the fiber patch cord and possibly an optical line reading from the Zhone must be taken first.
OpenNet charges a significant amount of money for activating them when fault lies on RSP/customer equipment thus it is not a practice of local RSPs to create activation tickets to OpenNet directly without first doing physical checks including an on-site.
Hope you understand where I'm coming from.
andr3wyong
Code:
Code:
Address:  8.8.8.8
          216.218.228.119
Server:  UnKnown
          216.218.228.119
Will check on the unreachable address.
As for the inability to look up records on pure IPv6 root domains (non-dual-stack) it's by design as the main DNS cache is still IPv4, though it should be brought to full dual stack sometime on the roadmap.
JeNoVa-IcHiGo
korkor rmb help me check for the email confirmation for the appointment. 3rd time amongst my friends that the appointment confirmation nvr came :<
Replied ur PM le korkor
koreanlover
Watching video stream (超清) on letv.com, but it is buffering heavily.
Can someone pls check ?
andr3wyong
Are you on Mac OS? You can try the following steps:
1. Open Terminal (Applications > Utilities > Terminal)
2. Type the following command, followed by Enter key:
Code:
telnet localhost <forwarded port>
3. You should see something similar to the following if the port on your computer is open:
Code:
macbook:~ andrew$ telnet localhost 44822
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
If it is stuck at "Trying 127.0.0.1..." then it means your software is not listening on the port.
JeNoVa-IcHiGo
But i want emewz :< everytime arrange appointment they say send emew but i check inbox no haf. my 2 frens also same case.
andr3wyong
Should have leh, if not they will call the contact on file. You can always email CS@vq to get them to update the contact details to your email and phone number if that's more convenient for you.
Anyway your appointment is confirmed liao :D
HexenHeretic
Code:
Code:
Trying 127.0.0.1...
nope, i'm on windows
but the "PC" i'm trying to do port forwarding is a synology NAS, for vpn server
what i did was:
1) the NAS is set to static ip e.g. 192.168.1.99
2) set port forwarding rules on NAS
3) set port forwarding rules on zhone, pointing to private ip 192.168.1.99
VQ NOC updated firmware of my zhone this morning
tried with portcheckers in office and wasn't working, i'll try to restart the NAS later when i get back home
andr3wyong
what i did was:
You can do the same thing on Windows (telnet check), however you need to go to Programs and Features > Add/remove Windows features > select Telnet client.
Eh anyway you should not need to port forward on the NAS itself :S was the port forward working before the firmware upgrade?
HexenHeretic
nope
it was working much earlier when NOC 1st toggled the firewall setting on my zhone, think it was around 24 june.
then i remembered my NAS was still on dynamic ip, then i proceeded to set static ip, change the port forward private ip on zhone, can't remember if i tested it out after making the changes until i tested it yesterday.
