Vinyl Flooring
calkel20
Yes and no, they do provided such service but they sub out to masonry workers.
Expect it to cost >$3.00 psf, cause they sub out.
Not necessarily if the clearance is enough, reputable vinyl installer will have machine for sanding door as this is a common problem for them. Expect to be quoted ~$80-100 per door if you opt for cheap vinyl, that's how they make money, try to bargain to ~$50-60 per door. =)
That amount u mentioned is the going rate.
Look online, can easily buy a rotary cutter for that amount and keep.
danielsmail
Yep you are right ! I did with my contractor for 2.80 psf and kitchen base about 4m for 250 only !
My door cutting was 80 too haha
bendi85
Shld i install vinyl first then install new doors or the other way round?
LouisSaha
Asking a question, for vinyl flooring, where to buy the stocks ar? Ownself do.... anyone know where to get is cheaper? Thanks
calkel20
Ask the vinyl company just for supply.
They do that.
Taobao is another option.
qwerty84
Currently my flooring is granite with skirting. Can the skirting be remove to overlay with vinyl or need to hack away?
slasherkenshin
Anyone tried tiles from Bamco ? (Charcoal Bamboo floor Tiles)
Saw their ads on FB and Youtube - seem to be a better quality alternative to traditional Vinyl tiles
