Vios owner group
EJB
It's at the accelerator side, a red button.
Turn the key, alarm will ring, insert key and set to ON (or was it ACC) then press the button.
nomoreliaola
hi ask you guys ... whats the reason for a car alarm to go off minutes after leaving the car ? i dun really remeeber if i lock my car (would that be a reason)? i only know that when i walk back to my house 1 min after i left the car, the car alarm rang those irritating kind ... then i went back and saw that it's my car ... so asking wat could be the reason?
EJB
Maybe something triggered the alarm, like a loose door sensor. That time my door sensor was faulty, while driving, my hazard will flicker on and off. Maybe same for yours.
nomoreliaola
thanks for quick response
1. if its a stock vios, if someone is to open the car door forcefully, would it trigger the alarm?
2. if the door is not closed tight, it will trigger ?
EJB
To my best of knowledge, which I never try before...
1. Unless it's damn forceful trying to break in or something, else I don't think so.
2. Yes it will, if you tried to lock it while the door is open.
fake_oranges
Alarm sot sot liao
Last time drive NCP42, my alarm very fast spoil
andyhtc
Suspended
car vios good or not bad?
The price has dropped to about $73,800 for the basic model if I recall correctly.
At this price, it is still higher than about $69,800 that was on offer last year. However, at current COE this is a reasonable price for the car.
If not, you can consider Honda Fit (cheaper) or Shuttle (about same price).
bendi85
Hi guys just bought a COE renewed vios. Whats is NCP? Is it the model?
Mine is 1.5E. What NCP is it?
Secondly which workshop u all usually go for servicing and repair? Looking for recommendations here in case got carrot head
Thanks!
EJB
Thanks!
There's a code name for the models.
NCP42 - the older older before 2007
NCP93 (aka Belta) - the ones looking like beetle (front)
NCP150 - new gen vios after Belta
NCP151 - current gen
bendi85
Oh..mine shld be 93 then
EJB
It only matters if you go outside buy parts yourself. Cos shops refer by model code name if not you have to drive down for them to make sure.
I call ric tat, I ask for drum shoes they ask me which model I tell them ncp93. You tell them year 20xx they where dare to commit...
