Waiting for colonoscopy!
Spike
i heard healthysg will give you a free colonoscopy when you hit 50.
can go private one?
By the time I get this free colonoscopy.. maybe I die liao. 😂
I just got a referral from polyclinic!
plaingrain
I wish you well @Spike .
I'm seeing a specialist in October and probably getting a scope done, your thread helps me understand a little more about what to expect. Thank you.
Roastduck
That's a very good question, and the answer is yes—but with an important qualification.
The pathology report shows that you had four sessile serrated lesions (SSLs). These are recognized precancerous lesions, but they do not mean that you were destined to develop colon cancer.
Think of it like this:
StageYour situation
Normal colon❌ Not anymore
Small sessile serrated lesion✅ This is where you were
Large SSL with dysplasia❌ You were not here
Early colon cancer❌ No
Advanced colon cancer❌ No
Your lesions were found at Stage 2, and they were removed before they progressed further.
What would have happened if you had never had a colonoscopy?​
No one can say for certain, but there are three possibilities:
  1. Some lesions might never have progressed.
    • Not every SSL becomes cancer.
  2. Some might have slowly enlarged over many years.
    • As SSLs grow, the chance of developing dysplasia and eventually cancer increases.
  3. One or more could eventually have become cancerous.
    • This is exactly why SSLs are removed when found.
So it's fair to say that your future risk of colorectal cancer would have been higher if these lesions had been left in place, but it is not correct to say that you would definitely have developed cancer.
The encouraging part​
Your pathology report contains two very reassuring findings:
  • No dysplasia (no precancerous cellular changes beyond the lesion itself).
  • No malignancy (no cancer).
That means they were caught early.
How much has your risk changed now?​
By removing these lesions, your gastroenterologist has likely substantially reduced your future risk of colorectal cancer. Colonoscopy is one of the few screening tests that is both diagnostic and preventive—it finds lesions and removes them before they can become cancer.
Looking ahead​
Because you've now been shown to form SSLs, you're someone who benefits from surveillance.
The plan is straightforward:
  • Repeat colonoscopy in 3 years.
  • Remove any new lesions while they're still small.
  • Continue healthy lifestyle measures (maintaining a healthy weight, regular exercise, a high-fibre diet, limiting processed and red meat, and avoiding smoking).
If you keep up with surveillance, the outlook is generally very good.
My overall impression​
If I had to summarize your situation:
  • One year ago, your biggest health concerns were blood pressure, cholesterol, glucose control, and gout.
  • Now, your blood pressure has normalized, your HbA1c has improved, your liver and kidney function are excellent, and your blood counts are normal.
  • The colonoscopy found something important—but it also prevented a potential future problem by removing precancerous lesions before they had progressed.
So I don't view this as bad news. I view it as a successful screening test that identified a risk early enough for effective prevention. The key is to stay engaged with the recommended follow-up rather than assuming the problem has gone away permanently.
Is time to do some changes to your diets.
Do consider to change to wholesome natural home cooked food as much as you can.
Spike
Well folks, good for your knowledge.
This is actually one of the most interesting areas in colorectal cancer research because we don't know the exact probability that an individual SSL will become cancerous. We do know that SSLs are bona fide precancerous lesions, but many never progress, and those that do often take years.
What we know from studies​
FindingEvidence
About 15–30% of colorectal cancers arise through the serrated pathway (SSLs and related lesions).This is well established in the literature.
Most SSLs never become cancer.The majority remain stable or grow slowly, particularly when they are small and lack dysplasia.
The risk rises substantially once dysplasia develops.Dysplasia is considered the major step before invasive cancer, and progression can accelerate after that point.
Removing SSLs greatly reduces future cancer risk.Surveillance colonoscopy is associated with a marked reduction in colorectal cancer incidence after serrated lesions are removed.
Applying this to your pathology​
Your report shows:
  • 4 sessile serrated lesions (SSLs)
  • All were <5 mm
  • No dysplasia
  • No malignancy
That combination is actually the most reassuring end of the SSL spectrum.
If we ranked SSLs by risk:
LesionRelative risk
Tiny (<5 mm), no dysplasia🟢 Lowest
5–9 mm, no dysplasia🟡 Low–moderate
≥10 mm🟠 Higher
Any SSL with dysplasia🔴 High
Invasive cancer⚫ Established cancer
Your lesions fall into the green category.
An interesting modelling study​
A recent colorectal cancer modelling study estimated that, without screening, almost 96% of SSLs that eventually become cancers first grow beyond 10 mm. Only a very small fraction are predicted to become cancer while still under 5 mm.
That's important because:
Yours were all removed when they were under 5 mm.
In other words, they were detected at a very early stage.
What is your risk now?​
There are two separate questions:
  1. Risk from the lesions that were removed?
    • Essentially eliminated if they were completely excised.
  2. Risk of developing new SSLs in the future?
    • Higher than someone who has never had an SSL, which is why surveillance is recommended.
Recent long-term data show that after serrated lesions are identified and managed, the 10-year cumulative incidence of colorectal cancer remains low, and repeated surveillance colonoscopies are associated with a substantial further reduction in risk.
My assessment of your situation​
Your pathology has three features I particularly like:
  • ✅ Tiny lesions (<5 mm)
  • ✅ No dysplasia
  • ✅ Completely removed
The feature I don't like is:
  • ⚠️ There were four SSLs at age 44.
That tells me you're someone who forms serrated lesions, so I completely agree with your gastroenterologist's recommendation for a 3-year surveillance colonoscopy.
If you continue with surveillance and any future SSLs are removed while they're still small, your risk of colorectal cancer should remain much lower than if the lesions had been left undetected. That's exactly why colonoscopy is such an effective preventive tool in people who develop these types of polyps.
Spike
Thanks boss. No worries. I do eat home cooked food. 😆
Well...I guess I need to thank the gentleman who suggested that I should go for a colonoscopy early.
Spike
I got a fuller report!
This is actually a very important report, and it changes how I view your colonoscopy findings.
Previously, we only knew that 6 polyps had been removed. Now we know what they actually were.
Executive Summary​
FindingSignificance
CancerNone detected ✅
Dysplasia (pre-cancerous severe changes)None detected ✅
MalignancyNone detected ✅
Inflammatory bowel diseaseNo evidence
Right colon biopsyMild non-specific changes only
Left colon biopsyMild non-specific changes only
PolypsPredominantly Sessile Serrated Lesions (SSLs)
Overall, this is good news, but it also explains why your gastroenterologist recommended another colonoscopy in 3 years.
What was actually removed?​
There were four specimen groups.
A. Right colon biopsy​
Result:
Mild non-specific changes.
The microscope showed:
  • normal crypt architecture
  • no inflammation of concern
  • no parasites
  • no granulomas
  • no dysplasia
  • no malignancy
This is essentially a reassuring biopsy.
B. Transverse colon​
One polyp.
Diagnosis:
Serrated polyp, suggestive of sessile serrated lesion (SSL).
Microscopy showed the characteristic features of an SSL:
  • full-thickness serrations
  • basal crypt dilatation
  • asymmetrical proliferation
Importantly:
No dysplasia.
No malignancy.
C. Left colon biopsy​
Again,
Only mild non-specific changes.
No evidence of:
  • Crohn's disease
  • ulcerative colitis
  • dysplasia
  • cancer
D. Descending colon​
Five polyps removed.
Histology showed:
  • 3 Sessile Serrated Lesions
  • 1 Serrated polyp
  • 1 Normal polypoid mucosa
No dysplasia.
No cancer.
Total pathology​
Putting everything together:
Type
Number​
Sessile serrated lesions
4​
Serrated polyp
1​
Non-neoplastic mucosa
1​
So you did not have six advanced precancerous polyps.
Instead:
  • 4 definite/probable SSLs
  • 1 additional serrated polyp
  • 1 that wasn't really a neoplastic polyp
Why is this important?​
This is the key point.
There are two main pathways to colorectal cancer:
Traditional pathway​
Normal polyp
Tubular adenoma
Advanced adenoma
Cancer
Serrated pathway​
Normal tissue
Sessile Serrated Lesion (SSL)
SSL with dysplasia
Cancer
Your pathology places you on the serrated pathway, but before dysplasia.
That is much better than finding dysplasia or cancer, but SSLs are still considered clinically important because they can be precursors if left in place.
Why a 3-year repeat?​
Based on your report alone, the recommendation makes sense because:
  • multiple serrated lesions were found,
  • several were compatible with sessile serrated lesions,
  • they were distributed in more than one part of the colon,
  • they were completely removed,
  • but you have enough lesions to warrant closer surveillance than average.
A 3-year interval is therefore a standard surveillance approach for someone with multiple serrated lesions.
What reassures me most​
The phrases I like seeing are repeated throughout the report:
No dysplasia
and
No malignancy
These are the two most important sentences in the entire pathology report.
My overall assessment​
Taking into account everything you've shared over the past few months:
  • Colonoscopy with all visible lesions removed.
  • Pathology shows multiple sessile serrated lesions, but no cancer and no dysplasia.
  • Blood counts are normal, with no signs of anemia or another obvious systemic issue.
  • Kidney and liver function are normal.
  • Your main cardiovascular issues remain elevated LDL cholesterol, mildly elevated blood pressure, and excess body fat, despite good muscle mass and a high activity level.
Overall, I would classify your current health profile as:
DomainAssessment
Colon cancerLow immediate risk after complete polypectomy, but higher-than-average future risk, which is why surveillance is important.
Cardiovascular healthModerate risk driven mainly by LDL cholesterol and blood pressure.
Metabolic healthMild insulin resistance/prediabetes history, but good opportunity for improvement with further fat loss.
Physical fitnessAbove average for your age, with strong muscle mass and excellent activity levels.
The colon findings are something to take seriously in the long term, but they are also exactly the sort of finding where surveillance works well. The lesions were identified and removed before dysplasia or cancer developed, and continuing with the recommended follow-up colonoscopies gives you a strong chance of detecting and removing any future lesions at an early stage.
