Watercooling Coolant Questions
5star_pundit
is it better to get all the components and case on hand first before getting the WC stuff? so far I've been drawing my layout on paper and calculating the fittings and other WC components, but lots of it based on estimates.
eg. how to know when to use 90° or a double 45° fitting? if using PETG, could I just bend the tube instead of using the angled fittings?
using the angled fittings = look nicer but higher cost as need to buy more fittings
just bend the tube instead = more difficulty in bending but save money
Encrypted11
Should I decide to add GPUs to the loop, I will add the second radiator but rather unlikely.
Some background - I bought an existing rig with the whole WC already set up with dual GTX 780s in SLI with Swiftech Komodo water blocks. Since I'm new to this, wanted to see how it was done. Took everything apart :s13: and now rebuilding again leaving out the GPUs. Actually, quite simple. Just like plumbing.
PC plumbing :s34:
pikoman
GPU can just buy barrow/bykski, cost so much lesser and performance isnt far off 1~2c from EK (o barrow/bykski have addressable rgb for their blocks). It come with local warranty, you can buy some from a local distro, just search on carousell. Coolant, just search on lazada, there is a guy selling it there, so much cheaper than self import. For 1st time user try not to buy pastel coolant 1st, try those clear types like mayhem X1, pastel need proper prep or else it will clog up.
pikoman
There are alot of people using barrow/bykski nowaday with zero complains, doesnt mean its made in china it is inferior and they do import acrylic from europe for their blocks.
d3adc3II
It's better to get the case and components before planning for WC. Also, get the case that are meant for WC ( At this moment, PC-O11 Dynamic, and Phanteks Evolv X, Fractal Design R6 are the best cases for water cooling)
Once got the case and components, then you start to plan for WC.
d3adc3II
SGJoe86
Yeah, I was looking at the Fractal Design Define R6. In fact, I was liaising with their CSO as I was interested in getting Bykski waterway distribution plate and custom mounting it in the case, so the CSO was helping me with the measurements. He even advised me against using dual 360 rads in the R6 as there will be issues with the mounting and pipings. I'll still be pressing forward with dual 360 rads since there are some online builds that managed to fit that in.
I was intending to wait till Black Friday to hoot my major components from Amazon US, but my current PC may not last till then, so will be pressing forward with the component purchase this weekend.
I've already ordered 2x 360 rads and 1x GPU block from Bykski, the rest I planning to get EKWB from PPC, but will be on hold as per advised until I get hold of all my barangs :)
SGJoe86
Wads the rad and gpu block material??
GPU block should be nickel plated copper, rad is brass + copper. I didn't buy Bykski's fittings as they are aluminium; cross metal contamination would be a friggin nightmare.
shadow84
Glad to know u nvr kena this issue. Barrow fittings shld be copper. U can try them to reduce costs.
IMO, get the waterplate if you know u wun be changing case soon. Coz it is only compatible to ur r6 and u wun be able to sell off.
Encrypted11
Ts may also want flush the rads thoroughly, typically there's residue in the radiator chambers from the production stage and the cleanliness varies from manufacturer to manufacturer
SGJoe86
Won't be getting the waterplate as Fractal's tech had done the measurement for me and said no-go. The waterway I was eyeing was meant for Lian Li PC-011 Dynamic, insufficient pump clearance from front rad if using on R6. :(
joshuaho
Been using barrow fittings for past months, I'm quite satisfied with its quality. Have tried the OEM kind that uses a push in method for hard tubing instead of the normal compression kind, it is still holding up well, as Long as no unnecessary weight is placed on it.
Also swapped between bykski, swiftech, EKWB, barrow, aqua computer GPU block, feel that bykski and narrow blocks are at a good price point, but the weight of the block is noticeably heavier, so it does increase GPU sag.
Pump wise, running dual XSPC pump for redundancy previously, suffered from consecutive pump failure. Lucky for me didn't damage my system as I noticed a warning notification for temps. Have been running dual barrow D5 pumps in the same config for over 2 years now, no issues so far.
PETG I used to be using bitspower, but have since changed to barrow, I would say quality is actually quite similar, just that I find barrow melts a little bit faster, so it might be easier for some to bend.
SGJoe86
Thanks for the useful tip on Bykski GPU block. I'll be installing it vertically since it's water cooled, so air flow and card sagging shouldn't be an issue.
Are you running dual pumps in a single loop? If yes, are both PWM controlled or running at 100% all the time?
Carbine90
Got all my parts for arnd 500$ From taobao and carousell . Only cpu waterblock, acrylic tube. Running on tap water with biocide. 2years so far so good
shadow84
Please dun use tap water w/ biocide. At least use distilled water. There are a lot of minerals in tap water that biocide cant kill. It will corrode ur waterblocks coating and material.
