Watercooling Coolant Questions
shadow84
Petrol station will surely sell also coz cars need distilled water if not their rads will corrode like hell le.
royfrosty
Quick question, where can I buy distilled water? Locally i mean
There is plenty at supermarkets.
However check the contents first before buying. Some distilled water got some contents of mineral salt inside.
Usually check the contents that it has nothing inside.
To be safe, you can buy DI water.
Carbine90
Please dun use tap water w/ biocide. At least use distilled water. There are a lot of minerals in tap water that biocide cant kill. It will corrode ur waterblocks coating and material.
😱😱😱 ok noted. Thanks man! Hope its not too late.
SGJoe86
Fellow experts, wanna check on where did you go to purchase the fluid for flushing the system? I just did my shopping on PPCS, realised all their system flushing fluid is not suitable for shipping via DHL.
5star_pundit
Thanks for the useful tip on Bykski GPU block. I'll be installing it vertically since it's water cooled, so air flow and card sagging shouldn't be an issue.
Are you running dual pumps in a single loop? If yes, are both PWM controlled or running at 100% all the time?
I control the pump speed by connecting the pump to the 4 pin pump header on my B350 tomahawk motherboard and then control it through the MSI BIOS
Koenig168
Distilled water from NTUC will do just fine.
SGJoe86
Hi all, another question today. My Bykski radiators just arrived, but I found out there are loads of metal burs inside the radiator piping, to the point my radiator sound like a rattle toy :s22:
Is it normal even for other brands (ie. EKWB, Alphacool), and will regular flushing do the trick, or will it damage the pump and clog the blocks when the burs started circulating the system?
shadow84
It is always recommended to do flushing before actual usage, regardless of brand. If not, u will damage your pump motor, let alone clog your blocks.
Pour distilled water into your rad and use the stop plugs to cover the ports. Then shake it in all directions to try clear up as much as possible. I believe this wun clear all debris, but at least can leave some fine 1 which wun damage the pump a lot.
The only real practical way to clean is to run water thru the rad constant and with a filter to catch those dirt. But im not sure if WC has this component or not. Im just taking reference from real life work.
Koenig168
I flushed my radiators with a high pressure hose and tap water, followed by the usual flushing with distilled water.
If there are loose metal bits, you do not want them damaging the pump.
SGJoe86
Saw from another thread where the user have inline filters before the blocks to pick up impurities, but each filter equates to two additional fittings :s22:
I'll try flushing it out with garden hose, hopefully it will flush everything out. Learning something new everyday :D
joshuaho
Yes it does smell, of course do in toilet or something.. not somewhere you eat and sleep at :s22:
I use around 30-40% ratio, plus minus some cause sometimes lazy to measure exact. Usually when receive new rad, will just let the vinegar solution sit inside overnight. Then flush out the next afternoon/night
wouldn't the whole place stink? what's your vinegar to water ratio?
SGJoe86
The vinegar you using is the typical white/clear vinegar that can be bought from supermarket?
Koenig168
Does SLS sell water-cooling soft tubes? Alternatively, is there a local online seller?
My tubes from ebay arrived with kinks and thus unusable.
TIA.
SGJoe86
TIA.
Did the seller not packaged it properly, or was the package damaged while en-route?
Koenig168
Both, already put in a replacement request to Seller but do not wish to wait that long for replacement to arrive.
shadow84
TIA.
U can try XS or scorpia but the latter will chop minced carrot out of u. If not, try Ban Leomg website. While they do carry some bitspower stuff, im not sure on stocks lvl.
Koenig168
Thanks, took a look at the Ban Leong website but they do not carry it. Will check out XS.
