Thanks, took a look at the Ban Leong website but they do not carry it. Will check out XS.
I think XS also low or no stocks le. Mostly carry hard tubing. U can fb msg them first. Best bet is buy from barrow tb.
How long of the soft tube to you need? If it's a short segment, I might be able to spare as I have ordered 3 ft of soft tube for fill and drain purpose.
I Might have some spare tubing, what’s your ID and OD?
hi guys, sorry to hijack, is 360mm rad overkill for just CPU loop?
intending to get a Byski set for a loop in the Lianli PC-O11 Dynamic.
Also, where can i get those colored coolants locally? Specifically looking for those white swirly/pearly coolant. Asking because taobao forwarding does not allow liquids.
If not overclocking, 120mm is actually enough. As I read somewhere before, every 120 for a component, 240 if OC. 360 does look nicer as it fills up the casing![]()
just another question guys, say if i want to add gpu block to my loop, if i want to install, it will void the warranty right? Is there no other way to do it to not void the warranty? Notice cus my card warranty sticker is directly on the gpu backplate screw itself...
I guess it depend on the brands: do a quick Google search and I found EVGA does not void warranty as long as no burn marks, water damage, etc., and you RMA with the original cooler back on.just another question guys, say if i want to add gpu block to my loop, if i want to install, it will void the warranty right? Is there no other way to do it to not void the warranty? Notice cus my card warranty sticker is directly on the gpu backplate screw itself...
Why physical shop and not get from online? Lazada have quite a few. Or you want to look at the physical item to see the color?Hey gurus, can recommend physical shop to buy mayhems pastel?
Raising this thread again because I'm facing issues with my set up. How to you guys bleed the system of air bubbles?
When I topped up the first time with distilled water for the 12 hours flushing, there were a lot of bubbles, but subsequently it cleared away. Now I've put in my opaque red coolant from thermaltake, there's a crazy amount of bubbles in it.
