Gymrat76
- May 8, 2003
Thanks, I started playing around with it. It's pretty good and I like how I can set my rear intake fans to match GPU temps instead of the default CPU temps (or a combination of both) as I want that to cool my RAMs and SSD more than the CPU.
Left the GPU controls alone as I think the factory setting is working well for me. From a quick test I think my temps are a little lower but will need to game a bit longer when I have time and monitor to see if there are truly improvements. Will also be good once my Scythe Kaze Flex slim fans arrive so I can play a bit more with it. With only 2 fan headers on this mobo (excluding CPU), will need to bunch a few fans to the same control, but that should work fine
Installed the Kaze Flex slims as bottom intakes and I've seen so far a GPU temp drop of around 2-3C at load.
Been trying to use the fancontrol software to set a curve for the bottom intakes to be as close as that of my GPU, but just realized I'm not able to set the case fans to 0 RPM (like for my GPU in fan stop mode...300RPM or so seems to be the minimum). Would have been nice to be able to do that so that the fans only kick in around 60C when it's under load like for the GPU.
Adjusted my CPU fan curve 30% until around 55C before it ramps up to 95% at 80C.. similar with top exhaust except it starts ramping up at 60C.. No point I guess to keep fans spinning faster than they're needed if the temps are at a safe level?
