What PC speakers are u using?
The_King
looking to replace my 12 to 14yr old setup (cant remember)
currently B&W 685 S2 with emotive dc1 DAC (the usb spoil, so now using optical) and a100 amp
any pro?
replace all, or keep using it and replace DAC? if so which DAC or if replace all, self power 6.5inch driver speaker + dac ?
The_King
Get second-hand "B&W S1" series speaker (Can be 601,602 or 607) and Fosi BT20A amp.
Your ears will thank you and that setup will last you for years, despite the low budget.
It costs slightly more then A2+ but way better than A2+ and even A5+
just saw your post
waht DAC you using?
rarenick
still using my trusty Creative Katana X (gen 1)
Read HWZ Forum Rules!
Got space to put the big sound bar in front? Your monitor is mounted?
occifer
After listening to the Elac 5.2 for some time now, i do hear an improvement over the edifier. A small improvement
Crimsoon
Hi, is it worth upgrading from Bose Companion 5 to a 5.1 Speaker system? I am using the BC5, and looking to upgrade my sound system but not sure if 5.1 is a big difference, compared to the "virtual 5.1 surround sound" offered by Bose Companion 5. And what speaker system would you recommend as an upgrade to BC5? I am looking for detailed/clear mids and highs.
TitanSmall
I am not using any speakers now. But thinking of getting one for my kids HBL.. I just need a serviceable and cheap one. Any suggestions pls? Thanks!
naked123
my table not big so i bought edifier mr4
not bad overall. no need sub
